  • Guests: 46
12/23 David (39)
12/25 Kolas (18)
3d cad software
Sun Apr 13 2014, 02:07AM Print
any recommendations for a good freeware 3d cad software for the imac?
it needs to do STL files
wings3d?
openscad?
thanks.
stop4stuff
Sun Apr 13 2014, 11:29PM
stop4stuff Registered Member #64 Joined: Thu Feb 09 2006, 06:25AM
Check out the list of 'supported applications' over on Shapeways Link2
Storken
Tue Apr 15 2014, 03:11PM
Storken Registered Member #1960 Joined: Thu Feb 05 2009, 11:57PM
Solid Edge (very similar to Solid Works), if you can pass as a student.
Fri Apr 18 2014, 08:52PM
Does anyone here have their own 3-D printer
are these more than just a toy
I've been looking into the maker bot and the associated clones
Carbon_Rod
Sat Apr 19 2014, 05:33AM
The basic Prusa i3 with RAMPS work quite well:
The 1.74mm filament with 0.4mm nozzle is quite accurate if printing 1 part at a time.
Tricolour Mendel is a bit more:
Some use a spool ($15 to $20 a Kg) of PLA and ABS, as the PLA when used as support material can be dissolved easily.
There is a skill set you must learn when building and running these machines:
* These are not really that user friendly if you aren't technically proficient, and you will have to calibrate the firmware with the plastic on a given machine. Additionally, aligning the print head clearance to a build bed surface for the first layer is critical.
* Without a heated build chamber PLA will pretty much allow any sized print without splitting, but is rather brittle being a cornstarch based plastic.
* ABS is actually usable (use outdoor exhaust fan), but to prevent warping or splitting does need a heated build chamber to anneal objects.
* Do people remember to regularly oil the bearing rods and lead screws? No, you can find used units very cheaply as people simply give up trying to get them to function.
Remember, the first print after calibration should be a set of replacement parts.
wink
