  • Guests: 56
David (39)
12/23 David (39)
12/25 Kolas (18)
Alternative
Ernie
Wed Apr 16 2014, 10:15PM Print
Ernie Registered Member #6129 Joined: Sun Aug 12 2012, 04:33AM
We put a diode in a power line, it allows movement in one direction only, but it has a voltage drop, is there a way to do the same thing without a voltage drop. Thanks Ernie
Wed Apr 16 2014, 11:28PM
Theoretically NO, as switches of any type have resistance, even if mainly in the connections.
In practice the volt drop loss can be very small by using a transistor
switched synchrounously with the ac.
Modern low voltage output smps use 'synchronous rectification' with mosfet switches.
Early technology using mechanical switching/comutation controlled by a synchronous motor
could do 1/2-wave or full-wave rectification with very low switching losses,
as the switchng occurs at zero voltage crossing.
If you are using D.C. then I guess the simplest you can do
is to use a low voltage drop rectifier such as a schottky diode.
You could have a hall-effect device monitoring the current
which switches a transistor in place of the diode,
a much lower voltage drop but more complex.
Ernie
Thu Apr 17 2014, 12:11AM
Thanks Pal, appreciated. Ernie
Sat Apr 19 2014, 04:32PM
Yup, synchronous rectification. If it wasn't for this, the average PC SMPS would be about the size of a house brick and weigh about the same.
The transformers used run up to around 3 MHz now, and with the Transoner (tm) ones could be made in 120W dual mode units not much bigger than a matchbox yet provide better than Type 2 medical isolation.
