  • Guests: 72
Lyonel Baum (77)
Mattc1886 (17)
01/09 RickR (18)
01/09 TheBoozer (58)
01/09 invader (50)
Naquadah reactor, module one :)
Andy
Sat Apr 05 2014, 04:37AM Print
Just doing a overhaul over the thread, to make it more coherent.
Andy
Sat Apr 05 2014, 09:56PM
M
Andy
Tue Apr 08 2014, 01:54AM
Construction blueprints
Plates
1396922217 4266 FT1630 Plates
Frame
1396933333 4266 FT2630 Frameone
Tue Apr 08 2014, 09:50AM
I admit i am rather confused here....
What exactly are you trying to do and have as an end product?
Andy
Tue Apr 08 2014, 10:23AM
I'm trying to make a arc with a NST and blow the charged ions past plates, they will build up charge, type of like a AC-DC voltage multiplier or a winhusrt machine or other static machines, and then connect the modules together to do some high voltage experiments
The thing should make 200volt*300plates =60kv min(the arc distance of 0.5mm will set a max voltage) from 15kv, the below picture is the general layout.
1396953445 4266 FT1630 Threedone
