  • Guests: 84
08/24 voltek (49)
08/24 DJ Cosmo (17)
08/24 n8 (39)
o_O, a tiny 3D printed VTTC
Artlav
Sun Apr 13 2014, 08:50AM Print
Artlav Registered Member #8120 Joined: Thu Nov 15 2012, 06:06PM
A little VTTC/plasma torch with a 6П14П pentode, build on a 3D printed frame.
(What is the right name for such a device? It's not exactly a tesla coil, lacking a secondary or any transformer action at all).
1397377821 8120 FT0 Onhand
I called it o_O for it's appearance.
1397377821 8120 FT0 Top
Bottom:
1397377819 8120 FT0 Bottom
Schematic:
1397377821 8120 FT0 Sch
The 3D printer file for the base (sized for a soviet tube socket): ]vttc.zip[/file]
The choke coil is 75 turns, the main coil is 20 turns.
The little coil in the feedback turn does not seem to matter, i was just experimenting.
Not shown on the schematic is the input capacitor and heater wires.
The thing in action, lighting up a CFL tube.
1397377819 8120 FT0 Glow
The streamer is tiny, but is as hot as a laser sword, cutting through anything non-conductive.
Gas tubes light up much better when it's not burning, however.
1397377821 8120 FT0 Streamer
Sun Apr 13 2014, 09:43PM
Very cute .... I like it.
I never even imagined a 3d printed TC ... well done.
any signs of heat or other damage to the plastic?
it's obviously a good HV RF insulator.
Artlav
Sun Apr 13 2014, 10:22PM
Sulaiman wrote ...
Not that i can notice.
The tube itself heats quite a bit after a few minutes, however.
Mon Apr 14 2014, 08:41AM
looking at your circuit diagram,
is it the 24uH and Coc that determines the operating frequency?
does it start by itself or does it ned some 'help' ?
If you do a MkII version
you could consider winding the 24uH with spacing between the turns
(a space equal to the wire diameter is adequate,
you could wind two wires then remove one,
or use nylon fishing line between turns)
this would increase the 'Q' of the coil and less heat would be generated
('proximity effect' causing only part of the wire to be used)
Mon Apr 14 2014, 11:38AM
0_o indeed, well done! I would call this circuit a "plasma tweeter".
Artlav
Thu Apr 17 2014, 07:37PM
Sulaiman wrote ...
Here is a sim for that kind of a device: Huge link
You can play with the values.
The feedback capacitance (Coc) determines nothing, except how reliable it will start or something.
The frequency is basically determined by the value of the main coil, one that is 24uH.
Sulaiman wrote ...
Starts by itself, no help needed.
The streamer needs a touch to ignite, however.
Sulaiman wrote ...
Heat in the tube?
I might try that some day.
Steve Conner wrote ...
Yet, it is absolutely silent.
I thought a plasma tweeter is something like that - Link2 ?
Ash Small
Thu Apr 17 2014, 08:22PM
Artlav wrote ...
I imagine the frequency is above 20kHz, so is therefore above hearing range. While I don't know much about plasma tweeters, I assume one way to do it would be to modulate the power at audible frequencies in order to get the sound.
