  • Guests: 52
Simplest Steamboat.
Mon Sept 18 2006, 03:46PM Print
I was looking at sci-toys Link2 and read about the "simplest steamboat". This steam boat uses a sealed boiler with 2 tubes (2 tubes are only required for filling the boiler, the engine will work perfectly with only 1 tube) running out the back of the boat. As the boiler heats the water in it turns to steam, when it does the expansion forces water out the back of the boat. When the steam gets out of the boiler it hits an area of pipe that just had water in it, this makes the steam condense and refills the boiler with water, by suction, from outside the boat.
My boat uses a coil in the pipe instead of a separate boiler; this means there are no solder joints in the tube, which could leak. Because my exhaust tubes are so short my engine has a high resonant frequency and tends to jitter along making many fast ripples. (my next engine will have longer exhaust tubes to make the engine run at a lower bpm). I have a few pipes in the freezer (full of water) at the moment, I will try to bend some tighter coils this afternoon to see if I can get better results.
1158594203 53 FT0 Dsc00014
FastMHz
Sun Sept 24 2006, 06:24PM
FastMHz Registered Member #179 Joined: Thu Feb 16 2006, 02:08AM
Location: Hagerstown, Maryland - Close to Prime Outlets
One of the easiest ways to bend a tight coil without the tube creasing is to fill the tube with very fine sand.
