  • Guests: 24
RickR (18)
TheBoozer (58)
invader (50)
TheAncients (32)
01/09 RickR (18)
01/09 TheBoozer (58)
01/09 invader (50)
Etching Circuit Board Station.
Mon Mar 03 2014, 10:10PM Print
im thinking of putting together a more formal etching device, but the nagging question i have is this. is there a non metallic pump for moving fluid, or should i use a mover stir stick with an RC servo off to one side.
Any ideas?
Link2 Possible ideas.
Tue Mar 04 2014, 03:00AM
I bought an etching station from circuit specialists. It uses a small air pump to agitate the bottom with air bubbles which moves the fluid. So, there you go. Go to Home Depot and get a tiny air pump, run some tubing to the bottom and see what happens.
Hazmatt_(The Underdog)
Tue Mar 04 2014, 04:28AM
That Rubbermaid tub looks pretty flimsy to me.
I use a 5 gallon poly bucket filled to 3 gallons, with a fish tank heater.
I'm not saying that's the best way to do it, but it is cheap and fairly solid...even after 10 years.
Sat Mar 08 2014, 06:16AM
does H2O2 + HCl etchant need to be heated to be more effective? ( perhaps 78 F +/-2F ) id be able to get a small, cheap liquid heater cheap but its fixed at that temp...
or is heating this etchant a trivial improvement ? i have a fish bubbler thats already going to be added, but need to know if theres a hazard or a waste of time to heat H2O2 + HCl. obviously im trying to avoid ferric chloride.
im also having some polycarbonate sheet being thermo-formed, for 12US$ pretty cheap for a custom tank !
Shrad
Sat Mar 08 2014, 09:30AM
H2O2 + HCL is in fact H2O + HCl with O2 catalyst which helps by further acidifying the dissolved copper compounds
I think H2O + HCl + bubbles + T° will be as efficient as a reused H2O2 + HCl solution
Sat Mar 08 2014, 04:58PM
Shrad wrote ...
So your saying don't bother with the heater?
Sun Mar 09 2014, 06:28AM
HCl+ H2O2 is pretty nasty stuff by itself. Heating it could cause a rapid decomposition, so be careful.
ConKbot of Doom
Fri Mar 21 2014, 09:26PM
For a pump with minimal things in contact with the working fluid, check out peristaltic pumps. The only thing contacting the fluid being pumped is the tubing inside of it. The tubing does wear out over time though, so it has to be replaced, and I'd suggest keeping the pump above the fluid level in the tank after you prime it so if the tubing does fail, all your etchant doesn't drain onto the floor. Flowrates are a bit low for their size though.
The Laing DDC, which is very common in PC water cooling and has a large variety of different top assemblies available if you care to change it up, is magnetically driven, and doesn't have a shaft seal to worry about, and its wetted materials list doesnt look too horrible. Link2
Not sure if all of those would resist etchant, though, as an oxidizer and acid mix is sure to be on the harder side of things to handle.
Fri Apr 04 2014, 11:45PM
ConkBot, would silicone aircraft fuel tubing be compatible with a oxidizer like H2O2 ? that type of pump does interest me, and as youve said, id make it leak upon failure into its own container.
Ash Small
Sat Apr 05 2014, 02:42PM
I'm not absolutely certain that these bilge pumps have no metal parts in contact with the fluid to be pumped, but they run off 12V and are submersible. They are also extremaly cheap for the small ones, and even cheaper from Ebay. They also have high flow rates which can be reduced simply by using a reducer in the pipe: Link2
