Positive photoresist
Fri Apr 04 2014, 08:11PM
Registered Member #190
Fornell sells positive photoresist spray in Europe does anyone know where to get the spray or liquid in United States
Injectorall is expensive
Ash Small
Registered Member #3414
Thanks.
Does anyone know which is easier? Liquid or spray?
I plan to use this for the silkscreen on the PCB. I will use my standard photoresist boards to make the circuit pattern. I will then etch the boards. Then, I will coat the board with the photoresist and imprint the component silkscreen. I have found the toner transfer method to be too variable in quality.
