  • Guests: 32
aonomus (38)
12/07 aonomus (38)
12/08 Wizzup (30)
12/09 Killa-X (34)
Parallel communication with TFT or LCD display
Andy
Sat Feb 15 2014, 02:26AM Print
Hi all
I'm trying to workout how to send commands to a display, the wire diagram list the parallel ports, but I'm abit lost on the other parts of the interface.I'm just trying to understand how it works, not so much spoon-feed code, a overview of the system would be helpful.
Thanks
Link2 TFT
Link2 LCD
Link2 LCD
Wastrel
Sat Feb 15 2014, 04:53PM
Wastrel Registered Member #4095 Joined: Thu Sept 15 2011, 03:19PM
Look at the SPLC780 timing diagrams, 6.5.6 for write and 6.5.7 for read. That is what your interface has to do to read and write to that chip.
Shrad
Sat Feb 15 2014, 05:55PM
I'd frankly use a serial interface
code is simple and as long as you have established the link, you just have to send text commands as specified in the screen datasheet to update it
Andy
Sat Feb 15 2014, 09:47PM
Thanks Wastrel , I normal skip over that picture, looking at 6.5.6
say I want to send 1 high bit on DB0
if I set RW high and RS and DB0 to high then lower then RS then set E high then DB0 high then invert all the pins?
Or can RS and DB0 stay high throughout the thing?
Shrad I might for the TFT, but going to test the LCD and otherparts, and will do the TFT display last in the project.
Shrad
Sun Feb 16 2014, 10:30AM
can't you use a library? there are some that manage most of the controller chips
Andy
Sun Feb 16 2014, 05:59PM
The examples that I've seen do not explain how to select the pins for the communication, using PMP libary.
And would like to understand whats happen under the cover.
Wastrel
Sun Feb 16 2014, 06:03PM
Assert chip select if needed, usually by sending it low.
Set RS to whatever it needs to be, I don't know what it does offhand.
Send RW (which is Read Not Write) Low.
This is one operation so long as they are all on the same port, one access. Minimum wait.
Send E high. Second operation. Minimum wait.
Put your data on the D pins. Third operation. Minimum wait.
Drop E. Last operation. And then minimum wait time before doing anything else.
That will write a byte.
