  • Guests: 47
aonomus (38)
12/08 Wizzup (30)
12/09 Killa-X (34)
12/09 Luca (45)
ADC and ref pin
Andy
Tue Feb 11 2014, 05:14AM Print
Hi
Does not having the ref pin on a signal chip ADC effect much of the sampling. Do you connect it to the Vdd or ground.
Is there any reason to connect it?
Cheers
Carbon_Rod
Tue Feb 11 2014, 06:34AM
It provides two major functions:
1.) Matching the rail-to-rail swing of the signal source to maximize bit-depth resolution
2.) Providing accurate conversion results with a voltage reference (16bit and above usually require this setup)
In most cases a 8 to 12 bit A2D will just use VCC as linear regulators have minimal noise... with a cap...
Andy
Tue Feb 11 2014, 09:12AM
Thanks wasn't shore if it could be left out, wired it in. Just connected it straight to Vdd.
Would it be better to have a inductor or capacitor wired in parallel or series to help.
Bjørn
Tue Feb 11 2014, 11:39AM
1. Read the datasheet.
2. Use a separate wire from the reference pin to the voltage regulator so you don't get excessive switching noise.
Andy
Tue Feb 11 2014, 06:38PM
Hi Bjorn
The MCP3550/1/3 devices accept single-ended
reference voltages from 0.1V to VDD. Since the
converter output noise is dominated by thermal noise,
which is independent of the reference voltage, the
output noise is not significantly improved
by
diminishing the reference voltage at the VREF input pin.
A reduced voltage reference will significantly improve
the INL performance (see Figure 2-4); the INL max
error is proportional to VREF
2.
Will add a separate wire thought, just curious why it say it won't do much?
Mon Feb 17 2014, 02:57AM
You can set the reference voltage to what you want to call maximum. If your chip takes 5.1v you can set the reference to 5v. Here, 5v will correspond to the maximum number of bits set high for the ADC. If it is a 10-bit ADC you will have 1023 as the value.
Andy
Mon Feb 17 2014, 05:46PM
Thanks Iamsmooth, Would it still have a value of 1023 if the voltage was half of what the chip takes, or is the 1023 for the max.
I was under some impression that it wasn't necessary to connect the reference pin(just used to improve sensitivity), but I'm guessing it won't work without it.
Dr. Slack
Mon Feb 17 2014, 09:31PM
An important use of the ref pin is for ratiometric applications. If you excite your transducer *and* reference your ADC to the same voltage, then reference drift disappears from the errors, handy for weighscale or thermometer applications.
