  • Guests: 55
5 digit lcd display
Mon Jan 27 2014, 10:58PM Print
I want to build my own display. I found a suitable LCD display and it has a lot of pins. I guess I need a chip to switch to the desired digit. Is this a multiplexor? Would someone give me a chip that is reasonable for switching to one of five digits. I'm planning on using an arduino to send out the appropriate ABCDEFG segment lines.
Thanks.
Andy
Mon Feb 03 2014, 12:43AM
Hi IamSmooth
Link2 has a lcd controller Link2 pdf, not sure if this is what you want, I know jack about this. wink
Bjørn
Wed Feb 05 2014, 07:35AM
If it is a bare panel you should remember that they don't like being driven by direct current.
Avalanche
Wed Feb 05 2014, 08:46AM
If it is a 5 digit 7 segment display, I would use something like a 4056
You'd have 1 chip per digit, all 4 input lines connected together then you just strobe the chip/digit you want to update. Total lines would be 4 for data, plus 1 strobe per digit, so 9 lines in total. You could even do something fancy to reduce the number of strobe lines.
Wed Feb 05 2014, 03:37PM
I got this
I am assembling the parts. I've written the c-code for the arduino already. It will read from -325 to 100F by tenths of a degree. I will power it with a 5v wall adapter.
