  • Guests: 58
Few questions about electrolytic capacitors
Njubster
Sun Jan 26 2014, 03:32PM Print
Njubster Registered Member #6857 Joined: Sat Sept 22 2012, 08:25AM
Hi,
I really like this thingie Link2 , and I'm thinking about making one myself with a few modifications. However I cannot easily access to that big cap this guy is using.
So I wonder if I could make a large bank of el. caps (e.g. 4700uF 35V), how well would that perform? Would the stress from fast discharging caps damage them quickly?
EDIT:
Would this --> Link2 capacitor pack (44mF) be enough for a little spot welder?
Mattski
Sun Jan 26 2014, 10:50PM
You probably want on the order of the same stored energy to get the same results, so around 115J for a 12V 1.6F cap (.5*C*V^2). What you're proposing is smaller (44mF at 25V is 14J).
With a lower voltage larger value capacitor you'll get a longer pulse at a lower current, you're proposing higher voltage arrays which will have faster higher current pulses. I don't know if one will be better than the other for spot welding.
The capacitors will certainly die faster in pulse applications than non-pulse, especially if they're not designed for pulse duty, but my unscientific opinion is that they won't die too quickly.
