  • Guests: 53
How do you size a ziner diode
Andy
Mon Jan 27 2014, 09:03AM Print
Hi, I'm trying to protect a IC, I would like to limit the volts to 10, but the volts after a voltage divider might reach 100-200volts as quick pulses, with low current.
How would you size the zener, what parameters do you use?
Cheers
Andy
Dr. Slack
Mon Jan 27 2014, 09:11AM
How much current can the voltage divider source? You need to be able to handle that.
How much energy can the pulse deliver after the voltage divider? You need to be able to handle that.
What's the requierd operate voltage and damage voltage to the IC. You need the zener specified so that it lies between those in the worst case.
But I don't think I've really told you anything here that isn't obvious.
Another option is a diode to the IC rail, as long as the capacitiance on the IC rail is sufficient to handle the charge delivered by the pulse from the voltage divider.
It's also good practice to put a series resistor after the clamping diode before the IC input pin.
Andy
Mon Jan 27 2014, 09:20AM
Is the zener measured in watts, or the amount of resistance the zener has, sorry ambiquious question, can I just put a couple in parallel and as long as the current from the source be handled or diverted, it will stop the voltage raising?
The IC can handle 15volt(maybe 18 max)
What do you mean by diode on the IC rail, in parallel or in series?
Is the resistor after the zener to limit the current in-case the zener changes with something?
Dr. Slack
Mon Jan 27 2014, 12:35PM
I think you ought to start by looking at a zener diode data sheet.
Its disspiation will be measured in watts. Its accuracy together with its slope resitance will tell you whether you can parallel them, I suspect the answer is probably not.
I said diode 'to' the IC rail, not 'on'. The concept is that instead of an X volt zener to ground to clamp a signal to x volts above ground, you use a silicon diode to the IC VCC rail to clamp the signal to VCC + 0.6v *as long* as the rail can sink the current that would flow to it. If it's a short pulse, then a big cap should be sufificnet.
A resistor between your clamping device and your damageable pin reduces the current that can flow into the node in the event of a transient spike on the clamp, or in the case of a diode and expected slight over-voltage. Another way to look at that is that the series resitor and the IC's internal input substrate diode do the 'protecting', as long as the voltage on the resistor and so the current is limited to something very reasonable, which allows you more freedom in specifying the clamp device.
Andy
Mon Jan 27 2014, 05:52PM
Thanks Dr Slack
Didn't know you couldn't parallel them, and didn't think about the forward drop clamp.
