  • Guests: 26
Dago (37)
Z28Fistergod (39)
JonIverson (45)
Liquidspaceman (67)
12/07 aonomus (38)
12/08 Wizzup (30)
12/09 Killa-X (34)
Gas Discharage Tube specification question
GammaRay
Thu Dec 26 2013, 10:10PM Print
GammaRay Registered Member #5323 Joined: Fri Jun 15 2012, 02:14PM
I want to protect a capacitor from ever seeing more than its 10kV input rating and am considering using a BOURNS Gas Discharge Tube for protection (image and specs below). The DC BREAKOVER VOLTAGE is listed as 8.64kV and the IMPULSE SPARKOVER VOLTAGE is listed at 10kV. Question: What is the difference between these two specifications and which should I pay most attention to if I want to protect my cap from ever seeing more than 10kV?
1388095765 5323 FT0 Gas Discharge Tube1
Thu Dec 26 2013, 10:21PM
depends upon the power source,
for a low current source the breakover voltage is the primary parameter,
as soon as the voltage reaches the breakover voltage the gdt will start to conduct
and discharge the capacitor,
IF the power source could impulsively supply 50 kA then the voltage could briefly rise to 10 kV
since I doubt that you have a high current source charging the capacitor
it would not exceed c8.64 kV
Note;
once the gdt has fired it will stay conducting as long as current is supplied to it
so a secondary cutoff may be required to prevent fire/explosion etc.
Fri Dec 27 2013, 12:10AM
I see from the Bourns data sheet that the "C" in the part number of your Gas Discharage Tube signifies a tolerance of ± 20%.
The voltage rating of capacitors is as subject to some degree of tolerance as any other component, so you'll see that in a worst case of 20% higher breakdown voltage of the spark gap, and not much negative tolerance on your capacitor voltage rating, could see your device fail. In any event, the margin is too small to be considered as good engineering practice.
You'll also see from the Bourns data sheet that the parameters of their Gas Discharage Tubes in this class change very quickly after a low number of discharges. You can't be running it like a sort of Zener diode, and have it clip off peaks every cycle. It's got to be a safety device of last resort, so it's a good choice to have in reserve when less expensive, less drastic, methods of preventing over-voltage have failed.
Mon Dec 30 2013, 07:41AM
PM, please tell me you have backups of your data sheets on something immutable such as Bluray? would hate to hear that you got Crypto'd etc.
I have access to some archiving systems here..
Mon Dec 30 2013, 08:43AM
a gdt (incidentally, where 4HVers use GDT to mean 'Gate Drive Transformer, the rest of the electronic engineering world uses GDT for 'Gas Discharge Tube') will not 'clip' waveforms like a zener or TVS, once a gdt has 'fired' it will stay conducting down to a very low voltage, 20V in this case. So just about ALL of the capacitor stored energy will be dissipated/discharged, rapidly.
The capacitor, gdt and total loop inductance will behave somewhat like the primary circuit of a sgtc
So add resistance in series with the gdt to limit the peak discharge current
(e.g. R > (Vpk/Ipk) and 'dampen' the oscillation.
the resistance must also be low enough to limit the power source
(e.g. R < (Vpk/Isupply)
Proud Mary made a good point about voltage tolerances, but the gdt is used as a method of last resort, that is, it should only operate infrequently under fault (overvoltage) conditions.
You need to find the peak voltage that your capacitor can tolerate from the datasheet, probably the 'test' voltage which is usually 1.5x to 2x nominal peak voltage,
then choose a gdt that has a voltage tolerance lower than the peak voltage AND higher than your peak expected operating voltage.
Mon Dec 30 2013, 11:54AM
Sulaiman is completely right about what he says about the voltage drop across the tube, and I should have made myself clearer.
