  • Guests: 55
kywalda (63)
12/20 plazmatron (48)
12/20 rm203tech (17)
12/20 Duality (16)
Geoneutrino detection
Wed Dec 25 2013, 07:29PM Print
Hi all.
Just found a fascinating paper suggesting that geoneutrinos from 40K could be detected using cadmium, or possibly copper 63 (63Cu)
If so then a detector could be made using isotopically enriched Cu waste from PCB manufacture.
Sound feasible, as the relative abundance is 0.6%
-A
Bored Chemist
Sat Jan 04 2014, 05:28PM
The abundance of 63Cu isn't 0.6% it is about 0.6 i.e. 60%. There's not much call for isotopic enrichment.
Can you link to the paper?
Sun Jan 05 2014, 09:59AM
I think the idea here is that 63Cu isn't the best candidate, but cadmium can indeed be enriched in this way using a gas centrifuge.
In fact all those "useless" NiCad batteries if reprocessed could allow a neutrino detector to be made and the excess Cd recycled as solar cells smile
-A
Andy
Sun Jan 05 2014, 06:23PM
Just throwing this out there, but would a neutrino have a mass of 7.9E-32kg, or doesn't it have any mass at all?
Ash Small
Sun Jan 05 2014, 07:59PM
Andy wrote ...
They are generally mass-less, however, recent developments suggest that, when they pass through a medium other than a vacuum they 'aquire' mass by interacting with the medium, and their velocity is also 'medium dependant', as is the speed of light.
Andy
Sat Jan 11 2014, 04:04AM
Hi Conundrum
I think Cadmium would work, GaSrCd , being used with scintillators, thoughts?
Sat Jan 11 2014, 08:00AM
Could do, certainly worth a try.
There's certainly a lot of it around thanks to all those perfectly good NiCads being trashed.
In fact one idea for anecdotal reports of neutrino sensitivity in CdS screened sensors was just this.
