  • Guests: 40
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Series diodes - forward current capacity question
GammaRay
Sat Jan 11 2014, 06:36PM Print
GammaRay Registered Member #5323 Joined: Fri Jun 15 2012, 02:14PM
In the case where a 100v@10ma diode is series connect with a 2nd 100v diode (but due to manufacturing tolerances the 2nd diode is actually 9ma), I understand that the reverse breakdown voltage of the two series diodes will be approximately 200v... but is the forward current capacity of the two series diodes limited to 9ma?
Sat Jan 11 2014, 07:12PM
What do you think, the same current passes through both diodes. smile
GammaRay
Sat Jan 11 2014, 11:19PM
I did a poor job stating my question, I will reframe it ill
When placing diodes in series, the amount of voltage they can collectively handle while remaining in a safe operating range effectively doubles (+/-), but does the diode's ability to handle current (before being destroyed because of too much current) also combine?
Stated differently, can a diode's ability to handle current be increased by placing a 2nd diode in series or will the current handling capacity always be the limited by the weakest diode in the series?
Andy
Sun Jan 12 2014, 04:23AM
Hi
I think its like resistors with the amount of watts the can withstand. Having a network array of parallel for current, and series for voltage
Sun Jan 12 2014, 07:09AM
Here is a good paper showing the difference between increased voltage handling by series connection and increased current handling by parallel connection. Link2
Dr. Slack
Sun Jan 12 2014, 10:56PM
GammaRay wrote ...
... I understand that the reverse breakdown voltage of the two series diodes will be approximately 200v...
yeah, well, not really, not in practice. Diodes have lots of other parameters, parameters you have no right to expect to be well matched between two random diodes. The one that really bites you in the bum is reverse recovery time. A forward biased diode stores a lot of charge, a bit like a large, poorly specified capacitor. As the two series diodes get reverse biased, stored charge flows out of the junctions, maintaining a very low voltage across the diodes. Eventually, one runs out of charge, and gets the full reverse voltage slapped across it. Ouch. Unless it's avalanche rated, exceeding the PIV by a factor of 2 doesn't do it a whole lot of good.
