  • Guests: 53
Dago (37)
Z28Fistergod (39)
JonIverson (45)
Liquidspaceman (67)
12/07 aonomus (38)
12/08 Wizzup (30)
12/09 Killa-X (34)
Smoothing a voltage doubler?
StormInABottle
Tue Dec 10 2013, 06:06PM Print
StormInABottle Registered Member #9252 Joined: Fri Jan 04 2013, 06:27AM
As you all most probably know. A microwave has a MOT connected to a voltage doubler. Then that goes to the magnetron.
But. Can i smooth the output of the voltage doubler so i can run the magnetron in CW? Would that be done simply by putting another MOC between the outputs of the Voltage doubler. Or would such a circuit be used? Link2
Tue Dec 10 2013, 10:07PM
Keep in mind, the magnetron is one of the diodes in the doubler.
So the later would have to do, I am still not sure how to evenly spread the power over the cycle.
Antonio
Sat Dec 14 2013, 08:42PM
The magnetron is not one of the diodes. It is in (anti) parallel with the diode. Look at the typical schematic and some details about a similar modification here:
The doubler with two diodes and two capacitors may work. I don't know if the magnetron can handle the increased power.
