  • Guests: 49
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
Induction heater
furnace
Thu Nov 28 2013, 09:28AM Print
furnace Registered Member #4992 Joined: Wed May 23 2012, 03:57PM
When cranking up the volts on my variac of the half bridge, the voltage on the gate of the first transistor starts to decrease cuasing shut down and failure to my brick at high power levels.Ive tried it with mosfets also and it still does the same thing and there is no ringing or paracitic oscillation showing on my scope.
Is anyone familiar with this?
Fri Nov 29 2013, 04:02AM
Schematic
furnace
Fri Nov 29 2013, 07:56AM
I have posted this already iamsmooth.
1385711770 4992 FT159330 Inductionschematic
furnace
Fri Nov 29 2013, 11:50AM
The scope also shows a voltage developing on the gate of the transistor.
Fri Nov 29 2013, 10:27PM
If you are following the schematic exactly it should work. Unless there are other suggestions, I would suggest swapping out new mosfets and new bypass capacitors. You can check if the mosfets are good; checking the capacitors is probably not easy. I just put in new ones. Make sure you are using the components I used on the schematic. If you use the wrong capacitors they will fail. Sometimes suddenly; more likely they will fail slowly and subtly.
Make sure you have the body diodes in place in the correct direction.
I am curious what happens if you remove the tank capacitor/coil to your waveform. If the gate voltage is going down I am thinking there is a short developing on the load end.
furnace
Sat Nov 30 2013, 05:24PM
Ive tried changing the mosfets and caps and i also removed the tank from the load but it stil does the same thing. Do i need body diodes if the mosfet already has an internal diode?
The bypass caps i have are rated .68 uf 1000vollts, Are these ok?
furnace
Sat Nov 30 2013, 07:50PM
Are the bypass caps ac/bipolar or dc caps?
Sat Nov 30 2013, 10:38PM
The fact that your asking means you are not following the schematic exactly.
You need body diodes as the internal ones are not reliable (or so I found)
You need the caps I listed (film caps)
0.68 seems high
I think I used .22uf
furnace
Sun Dec 01 2013, 12:24AM
I have .22uf on my tank. Question was on the 2 bypass caps as the schematic shows 1uf 600volts ac caps. Just wanted to be sure.
Sun Dec 01 2013, 04:46AM
0.44 to 0.68 should be fine
Switch them out and try new ones
Make sure they are pulse film caps
