  • Guests: 49
Dago (37)
Z28Fistergod (39)
JonIverson (45)
Liquidspaceman (67)
12/07 aonomus (38)
12/08 Wizzup (30)
12/09 Killa-X (34)
Modeling a spark gap, a sidac and a diac, help please
Newton Brawn
Mon Sept 02 2013, 03:49AM Print
Newton Brawn Registered Member #3343 Joined: Thu Oct 21 2010, 04:06PM
Hi All
I have start to use SIMetrix/SIMPLIS program and I need criate a model. I need a help to:
1- Modeliing a small spark gap >> min. rupture voltage 240V, min holding current 100mA.
2- Modeling a trigger diode (Diac) DB3 >> breakdown voltage 35V, breakover current 30mA
3 -Modeling a Sidac K2400G >> Breakover voltage 230V. min.holding current 60mA.
Any suggestion will be very welcome
Thanks
Newton
Tony Matt
Fri Sept 13 2013, 02:29AM
Tony Matt Registered Member #3700 Joined: Sat Feb 19 2011, 12:59PM
Hi,
You may download the Sidac 240V model fron the ON Semiconductors. Do not use the "copy and paste ", use the " save the target as " from the Windows pull down menu.
Somebody may help with the diac or spark gap model ?/
Tony Matt
Tue Sept 24 2013, 10:25PM
Hi !
Also you may dowload the models for Sidac from Littelfuse. It appears that they are more updated than other manufacturers
**link**
**link**
Regards
EDIT : SORRY, THE ACTUAL LITTELFUSE MODEL FOR SIDACS DO NOT WORK.
Tony Matt
Mon Dec 09 2013, 03:23AM
Hi Newton,
Here is a model for DIAC that works fine in SIMETRIX.
** Generic DB3, DIAC **
** IS THE SAME AS DB32GG, DB3G **
** By GG **
** Toronto 21 NOV 2013 **
** BASED ON LIttelfuse SINTAX **
** MODEL FROM A UNKNOWN CHINESE PUBLICATION **
** MODEL FORMAT: SPICE3 **
SRC=DB3; 32V 2A
*DIAC
*&#4##!
.SUBCKT DB3 1 2
* TERMINALS: MT2 MT1
* BASED from a UNKNOW CHINA orJAPAN SITE
QN1 5 4 2 NOUT OFF
QN2 8 6 7 NOUT OFF
QP1 6 8 10 POUT OFF
QP2 4 5 9 POUT OFF
D1 7 9 DZ
D2 2 10 DZ
DF 4 3 DZ OFF
DR 6 3 DZ OFF
RF 4 3 1.13E+7
RR 6 3 1.13E+7
RT2 1 7 0.755
RH 7 6 10K
RH2 4 2 10K
.MODEL DZ D (IS=321F RS=100 N=1.5 IBV=10N BV=30.3)
.MODEL POUT PNP (IS=321F BF=100 CJE=134p TF=25.5U)
.MODEL NOUT NPN (IS=321F BF=200 CJE=134P CJC=26.8p TF=1.7U)
.ENDS
It is nescessary to process the above text in WORDPAD and then saved in the Simetrix library.
Tony Matt
Mon Dec 09 2013, 03:37AM
Tony Matt wrote ...
Hi !
Also you may dowload the models for Sidac from littelfuse. It appears that they are more updated than other manufacturs
**link**
**link**
Regards
It is possible to fix the Littelfuse model. Changing the resistor RH to 5K, and the resistor RH2 to 5K the models work as a sidac....
