  • Guests: 55
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
how do I found out the max current on a voltage multiplier.
Fri Nov 22 2013, 05:48PM Print
Andre Registered Member #6921 Joined: Wed Sept 26 2012, 07:47PM
I have a 20 stage multiplier, but when I make it arc the caps keep dying
this caps:
I know I have to put a current limiting resistor but how do I figure out the max current the cap can take?
Fri Nov 22 2013, 08:16PM
Fri Nov 22 2013, 11:38PM
Proud Mary wrote ...
Thanks, is a nice table, but it does not calculate the max current of the multiplier. and that's what I'm looking for :)
Sat Nov 23 2013, 12:13AM
The maximum current is dependent on the regulation voltage.
Formula is here: Link2
woodchuck
Sat Nov 23 2013, 02:27AM
woodchuck Registered Member #39190 Joined: Sat Oct 26 2013, 09:15AM
Andre, you're operating against two liabilities. The first is that a 22-stage VM is liable to have terrible sag and slow recovery. Use SPICE to model voltage multipliers and you will quickly see that the wheels really start falling off after about eight stages.
The second liability is the capacitors you are using. They don't appear to be suitable for arc discharges. To test this I used a regulated 10kV supply and a 240 megaohm resistor to charge up a 1nF 15 kV cap repeatedly. Discharge was via an airgap at atmospheric pressure. In surprisingly little time (and with no appreciable heating) the ceramic dielectric's resistance had gone down to the point that it would no longer build up sufficient charge to arc.
It doesn't mean the caps are garbage - it simply means they're not designed to handle huge instantaneous discharge currents. In an x-ray tube power supply they might last forever.
Mon Nov 25 2013, 07:58PM
woodchuck wrote ...
Thank you woodchuck, that's good to know , great info!!
