  • Guests: 53
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
3kW IGBT Halfbridge Inverter *UPDATE 5kW*
1 2 3 4  last
RateReducer
Tue May 14 2013, 10:07AM Print
RateReducer Registered Member #4603 Joined: Wed Apr 25 2012, 07:33PM
Hi guys!
My new project...
I had 2 UI cores laying around. I made a big one out them. I glued the 2 Is on one U. So i have 1 large U and one small U -> giving me one big core wink
Secondary coil is a 5cm pipe with 600 turns 0,3mm wire.
The transformer is driven by a 300A 1200V IGBT halfbridge. Smoothed with 10.000µF xD
At the output i got a voltage doubler consisting of 2 x 4nF 40kV capacitors and 2 HV diodes stored under oil.
Img0672m
Img0765vi
Img0728qu
Img0712qy
Img0758if
I can draw 35cm Arcs and the power consumption is 230V~ 15A.
Enjoy!
Tue May 14 2013, 11:50AM
daymn, that is some huge arcs, where did you get the ferrite from?
what kind of driver is it? just a TL494, ->driver -> GDT -> Brick?
and also, are you planning to make a full bridge version of it too?
mabye audio modulate it... that would be cool!
whay kind of voltage is that about your getting out? about 16.2Kv if i did the calculation correctly
(320/2)/10 = 16v/turn
16*600 = 9600
9600*2 = 16,200v
Very nice!
Tue May 14 2013, 12:16PM
Looks good but I would definitely suggest taping the two blue DC bus cables together to reduce stray inductance!
RateReducer
Tue May 14 2013, 03:12PM
Thanks, __=|(:3)-|--{__ !
I got that ferrite form a huge choke which i got from a friend.
Yes, just a driver and a GDT.
Exactly: oscillator -> Mosfet driver - small GDT -> Mosfet half bridge (70V) - large GDT (18V) -> IGBT halfbridge.
Full bridge!? It already draws 3kW with the half bridge! amazed Can´t go higher ^^
Maybe i will modulate it, yes.
I don´t know if you can calculate it this way. When there is the right frequency on the secondary coil it gets in resonance increasing the output - so there is maybe more than 16.2kV.
But you could be right! I got a doubler at the output so there will be about 30kV.
It ark's over at about 3cm. If 1mm = 1kV it could fit! wink
EDIT: OK you already multiplied it by 2... But it looks like there is more voltage at the output than 16kV.
Thanks, Steve!
I twisted the blue cables!
I found something that reduced the power. A steel washer between the blue cable and the IGBT.
You may not believe it but the output increased noticeable when i removed the washer...
Tue May 14 2013, 04:05PM
why not measure the resistance across each side of the washer.... i wonder..
Tue May 14 2013, 05:38PM
Yep, you can't have any ferrous metal in the current path. It causes huge losses and gets dangerously hot. Copper, brass or non-magnetic stainless only!
You can get away with ordinary steel bolts for the terminals, as long as there's another path for the current to go around the bolt and not through it.
Tue May 14 2013, 06:03PM
I wish i could find some large ferrite like this for less then the $100s i see on most sites....
Tue May 14 2013, 07:59PM
Hehe, cool arcs, but I'm surprised the little PVC-wire primary doesn't melt after a while cheesey And be sure to add some RF-bypass capacitor across the IGBT input terminals.
RateReducer
Tue May 14 2013, 08:50PM
You are right Steve! I found it out by myself xD
Now the steel screw just pushes down the copper cable to the IGBT terminal.
__=|(:3)-|--{__ I could ask some people form a German forum. Some of them ordered big cores for far under 100$.
The primary gets barely warm. I am also surprised, Dr. Dark Current. The only thing that is getting pretty hot is the Diode (multi mini diode)
Some kind of Snubber? Ok i will attach that!
Physics Junkie
Tue May 14 2013, 09:09PM
Physics Junkie Registered Member #7267 Joined: Tue Oct 16 2012, 12:16AM
That's awesome. Roast some marshmallows with it cheesey
is that aluminum sheeting on the DC bus caps?
1 2 3 4  last
