  • Guests: 50
Sulaiman (71)
teslarevolution (29)
AromaZ (69)
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
500w Xenon Arc Lamp Skybeamer
RateReducer
Fri Oct 18 2013, 08:31PM Print
RateReducer Registered Member #4603 Joined: Wed Apr 25 2012, 07:33PM
Just wanted to show you guys my new Project wink
500W Xenon lamp with a reflector.
Fri Oct 18 2013, 08:55PM
Very nice! you totally need to try a batman logo with it
RateReducer
Fri Oct 18 2013, 09:22PM
Thanks!
Unfortunately it does not work...
I tried to hold my hand in the beam but you don´t see it in the sky, the beam just gets weaker.
Fri Oct 18 2013, 10:18PM
Pity... i wonder if there is any way to get something like that to work....
RateReducer
Fri Oct 18 2013, 11:26PM
The problem is the reflector. There is a focus about 2m above the XBO. You can see it at the end of the video, there are a few fotos.
the_anomaly
Fri Oct 18 2013, 11:45PM
the_anomaly Registered Member #19 Joined: Thu Feb 02 2006, 03:19PM
A parabolic reflector should give you a collimated output. Your reflector is probably more in the shape of an ellipse at the moment. Very cool work :)! How are you cooling it?
RateReducer
Sat Oct 19 2013, 12:31AM
On the bottom of the lamp there are some air slots in the reflector. I use a blower from a hairdryer which is directly mounted into a pipe under those air slots wink
Thanks!
Sat Oct 19 2013, 10:13AM
What an amazing thing!
