  • Guests: 44
Sulaiman (71)
teslarevolution (29)
AromaZ (69)
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
What Integrated Circuit would you Suggest for Full Bridge Driver Applications.
Chris Cristini
Thu Oct 10 2013, 12:03AM Print
My Goal is to make a driver for any application from SSTC to Fly back HV/LV. I would like current sensing capabilities from a Current Transformer, Full Gate Isolation, Adjustable Dead Time,
Adjustable Frequency and as much protection as possible for expensive ISOTOP FET's. This will be the first actual Full bridge driver I mostly build Half bridges and not much knowledge on Full bridges I have searched hours on the internet but I would like to here some Information from the best forum available in this subject.
Thu Oct 10 2013, 10:26AM
Well you can always use the omnipresent TL494, but you might better go with the SG3525 which has pulse-by-pulse current limiting option (and all the other features you requested), it just can't drive the GDT directly at high frequencies. BTW, the control circuit for half and full bridge is the same.
Thu Oct 10 2013, 12:39PM
UC3825 is faster and 'beefier'
Chris Cristini
Thu Oct 10 2013, 12:44PM
Oh less complicated than I thought can I use a darlington Pair to drive the GDT? Or would I be better off with Opto isolators.
TwirlyWhirly555
Thu Oct 10 2013, 03:42PM
TwirlyWhirly555 Registered Member #4104 Joined: Fri Sept 23 2011, 06:54PM
Just use regular gate drive ICs to drive the GDT you can find them cheap and work well
Chris Cristini
Thu Oct 10 2013, 04:48PM
Sulaiman wrote ...
Wow UC3825 even has soft start Capability I could not fully understand the Data sheet can it go below 100KHZ or will i have to use a lower frequency device and this device with some sort of switch to switch it to the slower IC when adjusting the Frequency POT?
And I will try to find suitable Gate drive IC's that sounds like the best solution.
EDIT: I apologize if this has been addressed before I will do much more research.
Thu Oct 10 2013, 09:53PM
look at the Unitrode components and app notes. (theres a whole list of really cool ICs, but ill share a list of my favorites, we cant have 800 different ICs as hobbyists like a big corp can.)
must go to class, will be back soon to say more...
Chris Cristini
Fri Oct 11 2013, 11:43PM
That would be nice to have availability too all I.C's for your own testing I am actually starting an Electronics recycling service that takes everything for free and I am going to De solder everything I get I might just have a huge collection and will have to get rid of allot of it I may be a great help to the Box or start a thread for a list of stuff the forum can have.
Chris Cristini
Sun Oct 13 2013, 10:58PM
This is what I wanted to make I may add Treble Median And Bass control for the Audio modulation.
0f0e20cbdef8 Zpsf33fb1c7
Chris Cristini
Tue Oct 22 2013, 06:12PM
What is everyone's thoughts on Zener diode gate protection for Half/Full/Single mosfet configurations?
