  • Guests: 24
OiD (38)
jolty (50)
Baran (29)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Combineing crystal for high freqency
Andy
Fri Oct 11 2013, 08:00AM Print
Hi
Is there anyway to combine crystal to get high frequency. I'm looking at Link2 and would like to get 450khz from three 153khz crystals.
Like to build this circuit Link2
Thanks
PSCG
Fri Oct 11 2013, 08:18AM
PSCG Registered Member #3792 Joined: Sun Mar 27 2011, 06:07PM
Combining quartz crystals does not work like combining capacitors, resistors or coils. You cannot connect crystals in series or parallel to make them work at a different frequency.
You must find a crystal that it's fundamental oscillating frequency is 450 KHz for the circuit that you specified, since it can't make use of overtone crystals (it will again oscillate at their base frequency).
Fri Oct 11 2013, 12:19PM
If you build a crystal oscillator
and 'square' up the output
it will have a very strong 3rd harmonic content
which can be filtered out and amplified.
The link to crystal oscillator that you posted is just what you want, squarewave output for filtering, amplifying/limiting
Of course, 3x 153 = 459 not 450 and I doubt that you could 'pull' the resonant frequency that far off natural
The crystal frequency is normally the parallel resonance frequency
if you make a crystal oscillator using series resonance the frequency will be a little lower
sometimes you can put a filter in the crystal oscillator to force the crystal to operate at it's third harmonic
crystals for this purpose are 'overtone' crystals
but a normal crystal should work in overtone mode. Link2
Fri Oct 11 2013, 12:58PM
You could substitute the crystal with an inexpensive 450 kHz ceramic resonator. Murata make one.
Andy
Fri Oct 11 2013, 05:38PM
Thanks Sulaiman,PSCG
Thanks Proud Mary, found a 500khz resonator, I'm guessing it could be dropped in place of a crystal.
Fri Oct 11 2013, 05:53PM
Andy wrote ...
Ceramic resonators will work in most circuits in place of a quartz crystal, though their Q and frequency tolerance are a bit lower.
