  • Guests: 38
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
GM tube woes, help needed :(
Pinkamena
Thu Oct 10 2013, 08:25PM Print
Pinkamena Registered Member #4237 Joined: Tue Nov 29 2011, 02:49PM
Hi everyone.
I've got a Geiger-Müller tube that I can't seem to act like I want it to. First, the schematic. It's very simple:
1381432575 4237 FT0 Geiger
Now, as a gamma photon passes through the GM tube (got a Cs-137 sample providing about 10 counts/s), it will short out, and I should read about 500 * 220/10220 = 10.7V. My problem here, is that I read closer to 50V! I am certain the oscilloscope is showing the correct value, and both resistors are the correct value, checked with independent multimeters. My HV supply is providing exactly 500V, and I have attempted to replace the GM tube.
Nothing fixes it! I've got no more ideas left. What could be wrong?
radhoo
Thu Oct 10 2013, 09:28PM
What do you measure if you just short the tube's connectors with a short wire, instead of waiting for the radiation induced pulse?
Pinkamena
Thu Oct 10 2013, 09:31PM
Then I measure the expected 10.7 volts! It's all very mysterious.
BigBad
Thu Oct 10 2013, 10:36PM
First, let me say I know absolutely nothing about GM tubes; but perhaps the tube has leaked a bit and so is constantly conducting.
50 v would be about the voltage drop I'd expect to get from an arc of some kind...
You could try putting a low voltage across it, perhaps it will stop conducting all the time, but maybe the tube is dud and cannot be salvaged.
Oh wait: "I have attempted to replace the GM tube. " dunno unless there's a bad batch or something
Fri Oct 11 2013, 03:33AM
can you post a pic of the o-scope pic?
i wonder if the capacitance of the GM tube is upping the voltage past what your DC voltage divider math predicts.
Pinkamena
Fri Oct 11 2013, 08:31AM
Patrick wrote ...
Will do when I get the chance. The GM tube has a capacitance of about 3pF.
Shrad
Fri Oct 11 2013, 09:26AM
or maybe your setup reacts to the radiation, like a transistor or something in the PSU
is everything shielded well enough? I guess a simple plastic case transistor would react under radiation, no?
Fri Oct 11 2013, 09:32AM
Does the GM tube have a type number and a datasheet? This is the place to start.
Uspring
Fri Oct 11 2013, 12:18PM
The anode of the tube has a capacitance by itself. When the tube fires, this is discharged into the 220k resistor. Whether this is a viable explanation depends on the size of the capacitance and on the duration of the discharge.
Pinkamena
Fri Oct 11 2013, 03:27PM
Shrad wrote ...
The radiation is not nearly intense enough for the electronics to get affected in any measurable way.
Proud Mary wrote ...
It's called ZP1200, but there's no datasheets on it.
Uspring wrote ...
I guess that makes sense. Not sure how I would fix it.
Anyways, I worked around the problem by replacing the 220k resistor with a 220k varistor, and reading the signal out at a varistor value that fit. So consider this problem solved!
