  • Guests: 36
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Anyone know a replacement for this: TL068CLP
coillah
Fri Sept 27 2013, 05:41PM Print
coillah Registered Member #1517 Joined: Wed Jun 04 2008, 06:55AM
Hi, just wondering if anyone knows of a replacement for this:
Fri Sept 27 2013, 09:01PM
Not sure if this is exactly what you want, but this should do the same thing:
MnSEaeX
Myke
Thu Oct 03 2013, 06:12PM
What's the application? It looks like the chip's just a op-amp wired as a follower in a nice package.
There are many better modern op-amps around.
Fri Oct 04 2013, 08:49AM
Yeah, hence why nobody uses the TL068 any more. tongue
The only thing that sets it apart from a regular op-amp is that the negative power supply pin is also the output pin. You might be able to find an op-amp whose input and output common-mode ranges both included the negative supply, and wire it like the TL068, but it would be better to just find a separate negative supply elsewhere in the circuit.
