  • Guests: 52
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Peltier cascade
Fri Oct 04 2013, 05:43AM Print
Hi all.
Well I built it, then ran into a problem.
1) the thermal pads aren't that conductive, paste would have been better.
2) the laws of thermodynamics. In order to effectively pump heat the topmost
device must be running at 1/9 of the current of the bottom device.
Or else what happens is that nearly all the electricity just heats the stack smile
3) Now they've been padded, they won't come apart!7
Ideas?
I have a few more of them so its no biggie, but would like to avoid damaging the
expensive copper units so if there's a method of getting the swines apart..
-A
Ash Small
Fri Oct 04 2013, 09:22AM
More detail please, Andre. Have you built it with a pyramid structure?
Fri Oct 04 2013, 07:41PM
The bottom unit is slightly larger, however the three top units are identical.
Ash Small
Fri Oct 04 2013, 08:22PM
Conundrum wrote ...
So if you have nine on the bottom layer, etc, you could run them all at the same current?
The main problem with Peltiers seems to be the need for a pyramid design.
Sat Oct 05 2013, 02:08AM
i need pictures please... and how does the AIM-9X sidewinder do it?
