  • Guests: 66
Driving a led with mains.
1 2 3 4  last
kimbomba
Mon Sept 16 2013, 08:03PM Print
kimbomba Registered Member #3854 Joined: Fri Apr 29 2011, 03:45AM
I want to drive a led with the mains. Using a resistance in series works, but some power is lost in the resistor. Would it be more efficient if i use a capacitor in series with the led? Any other option for driving the led with the less power comsumption lost in the driver itself? I dont want to use commercial drivers by the way.
Mon Sept 16 2013, 08:15PM
transformer?
You should look into using neon-indicators instead, more mains friendly. 0.5 mA instead of 20 mA.
What is the application? and mains voltage?
BigBad
Mon Sept 16 2013, 09:50PM
Never done it, but I think the cap trick does basically work, and that seems to be what is said here, but it looks like you also need a zener and a reverse diode/led to deal with transients and the reverse cycle:
johnf
Tue Sept 17 2013, 10:35AM
Just use two leds back to back and a capacitor of the right value to get the current you need 1/2x pi x f x c will get the capacitance you need
Dr. Slack
Tue Sept 17 2013, 11:44AM
johnf wrote ...
... and it will send the led domes flying across the room the second time you turn it on. You also need a series resistor to limit the inrush current that the capacitor can take if it's switched on at peak mains voltage. Consult the LED data sheet for the largest surge current it can stand, and choose the resistor accordingly. You might be surprised at how large the resistor has to be to limit the current to 100s of mA, or less.
I've used an electrolyitc capacitor across my unipolar LED string, partly because I don't like the 100Hz flicker and partly because it will absorb a large transient inrush without over-volting the LEDS. Even a cooking grade silicon bridge rectifier diodes will handle 10s of amps for one half-cycle, which means the series resistor can be a few ohms.
1379418241 72 FT157237 Leds
Ash Small
Tue Sept 17 2013, 12:39PM
This should work too. I think it will work with just one diode, too. It has a minimum of components, has a 'bleeder' resistor to prevent the electrolytic from staying charged (unless the LED fails 'open circuit'), and to limit the current to the LED, and will only draw sufficient power to keep the electrolytic 'topped up', I think..
1379421591 3414 FT157237 Led Mains Indicator
If it won't work, maybe someone could explain why?
EDIT: Maybe it should have a second 'current limiting' resistor on the mains side?
Dr. Slack
Tue Sept 17 2013, 07:02PM
What you've got there Ash is a rectifier for the mains, so 170 or 340 volts on the cap depending on which side of the pond you live. Then all the power gets dissipated in the resistor.
Ash Small
Tue Sept 17 2013, 07:30PM
Dr. Slack wrote ...
OK, thanks.
So adding a shunt capacitor (or two?) would limit the power drawn from the mains, presumably?
Dr. Slack
Tue Sept 17 2013, 09:26PM
No
Ash Small
Tue Sept 17 2013, 11:15PM
Dr. Slack wrote ...
No
I'm going to have to build this one, I think. wink
1 2 3 4  last
