  • Guests: 29
Sulaiman (71)
teslarevolution (29)
AromaZ (69)
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
What can I do with a Plasma Ball Transformer
Tetris
Wed Sept 11 2013, 01:15AM Print
I shouldn't be allowed to transport glass. I broke my plasma globe four days after I got it. I was bawling for hours. But that's besides the point.
I broke the glass. This was last Christmas. The transformer is good as new. Some of you know I have very, very, very limited, very low voltage parts access, with no capability of buying anything (I can only nab what I get from the electronics classroom.)
What can I do with the transformer? I tried making a flyback audio once, and that was a miserable failure. It hardly worked, but I think that was more on the fact I fed it an MP3 instead of a MIDI. Do you think I should try again?
This time, I'm more mathematically inclined, but I don't know more than the basic electrical formulas.
Wed Sept 11 2013, 02:49PM
Do you still have the original board? it should be possible to drive some other glass bulb with low pressure from it.
aka light-bulbs e.t.c.
Platinum
Wed Sept 11 2013, 08:15PM
I had one from an 8" plasma globe not so long ago, the driver was only an IC switched single darlington transistor, it was only 12watts output. For fun I put the flyback on a zvs driver, output diminished very fast.
They have uses, just keep it to low powers, say 10-25watts. You shouldn't have any problems then.
testtest
Wed Sept 11 2013, 08:31PM
testtest Registered Member #3271 Joined: Mon Oct 04 2010, 02:29AM
"What can I do with a plasma ball transformer..."
Ask Carl Willis to make you a replacement globe. You can see his work here
Dont know if your electronics could drive one however.
Tetris
Thu Sept 12 2013, 02:49AM
Erlend^SE wrote ...
I never took it apart. The only thing I don't have is the argon and the glass.
Platinum wrote ...
IIRC it was a 4" globe.
richnormand wrote ...
Hmm... maybe I could use a standard light bulb and draw arcs from it. As said, I can't afford to buy anything. I haven't HV'ed in a year... I need to pick it back up again.
[Edit: Triple post]
Experimentonomen
Thu Sept 12 2013, 07:38AM
Or do what i did and quit hv for good.
Ash Small
Thu Sept 12 2013, 09:03AM
You could try a few different lightbulbs, some work a lot better than others. There are quite a few articles out there on home made plasma globes.
There is a 'theoretical' risk of X-rays with some, but I doubt that will be a problem with your driver. Maybe someone else can confirm this?
Dragon64
Thu Sept 12 2013, 03:32PM
Dragon64 Registered Member #1438 Joined: Sat Apr 12 2008, 12:57AM
Ash Small wrote ...
If he is planning on using the plasma globe driver to drive the tranformer there shouldn't be a risk of x-ray.
As far as I recall, plasma globe only work on AC which shouldn't produce x-rays.
Alex M
Fri Sept 13 2013, 06:39AM
Experimentonomen wrote ...
How come?
Experimentonomen
Fri Sept 13 2013, 07:28AM
Drawing arcs from a flyback got boring, and i dident wanna get associated with all them noobs asking how to wire a mot and what not.
