  • Guests: 41
Sulaiman (71)
teslarevolution (29)
AromaZ (69)
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
Successfully Simulated Mazzilli ZVS Driver in Simetrix
Shaan
Sun Oct 06 2013, 01:00AM Print
Shaan Registered Member #5528 Joined: Sat Jun 30 2012, 06:53AM
Hello guys.
I built this driver quite a few months ago and since then have been mad-like in the pursuit to understand how it works. Am an audio guy, so HV stuff, power conversion and magnetics are usually out of my business; I understand them much less than say, effect of dominant pole capacitor on amplifier slew-rate hehe...
After a lot of wandering without getting any wave-shaped plot I finally succeeded in simulating the driver.
I have seen the animated Java simulation video in YT , but through simulating it myself a LOT of my questions have found their answers.
The most interesting thing l probed was on the resonant capacitor. It passes 20A RMS when running with the driver!!!!! No wonder some of my film caps have cracked/exploded thanks to Mr. Mazzilli. :P
The inductor, transformer and all the models used in the simulation is from the generic template/library that comes with the free simulator. The transformer has 3+3 primary turns and secondary to primary ratio of 10000. The setup is a bit crude, but works.
I have simulated countless audio circuits with it. It can sim the ZVS too...yoohoo!
Wanna show you some plots and fotos. They look gorgeous(well, at least to a newbie like me hehe)
The schema-
Zvs1
Secondary output voltage-
Zvs2
Resonant Capacitor current-
Zvs3
And some close shots of the driver in real life
Cracked capacitor-
DSC00089
Hand-wound HV output coil-
DSC00088
cheers
shaan
[Edit: Image width]
Newton Brawn
Tue Oct 08 2013, 02:45AM
Newton Brawn Registered Member #3343 Joined: Thu Oct 21 2010, 04:06PM
Hi Shaan !
Congratulations by the nice presentation of your project, and clear info about the results as well as your doubts...
I have started using the SIMetrix some weeks ago, and I am not complete familiar with the possibilities of the soft.
However I am more familiar with the magnetics and switching devices. I am starting simulating discharging caps throug sidacs, diacs and triacs so far.
By the way, I think a transformer 3+3:30000 turn ratio is not easy, to construct. (and energize it)
Metalized capacitors have the metal electrode so thin, thin that when a pulse of 20A pass the metal vaporizes... the solution is using the old caps ( oil paper dielectrics and aluminun foil electrodes....).
Did you try to use microwave caps in the place of C1 ? Some microwave caps are 0.9uF rated 2200V, oil and Al foilconstrution.
You may transfer the C1 to the secondary, try to simulate Tx1 as 3+3:300 turn ratio, with secondary connected to a 100picofarad cap rated 5kV (Tx1 has to have very low leakage inductance, couping factor ~1, )
100picofarad x 5000V is easy to be buit at home, using windows glass and kitchen aluminun foil.
Regards
Newton
