  • Guests: 34
Michael Witt (36)
AleSeg (15)
09/17 Jyardana (41)
09/17 Gunboat (72)
09/19 raff (48)
Serial Controlled Function Generator chips
Sat Aug 31 2013, 04:35PM Print
Hey guys,
Im currently looking for a Function generator chip that interfaces through serial so i can hook it up to a ATMega Chip,
Does anyone know of any good types?
Im planning for a range of:
at least 5-55% duty cycle control (5-95% would be awesome)
30-150Khz about
I have been looking around for a while but am unsure what to go for, id rather
not have a SMD Chip however.
Thanks!
EDIT:
Only thing ive found is this... and i really dont think i have much hope in using this frankly...
Link2 (I would hate to solder this...)
BigBad
Sat Aug 31 2013, 09:49PM
I know it's not quite what you're asking for but is this any good?:
Sat Aug 31 2013, 09:51PM
What kinds of functions are you seeking?
As far as I can see, you mostly describe PWM that the internal timers can do.
Do you plan to have the board made by others? or at home?
THat chip isn't too tricky to solder, it's mostly about knowing how.
Sun Sept 01 2013, 11:50AM
Im basicly after
30-150Khz Square wave with PMW Control
Nothing else really, ofc, i would prefure it to go upto 300Khz, but that might
be a bit much to ask for.
I kind of think that chip is hard to solder as its 8mm x 8mm and its got 40 or so tiny pins.
Thats all im really after, id prefure to do the board at home to keep costs down. i usually use stripboard.
Bjørn
Sun Sept 01 2013, 01:42PM
The ATMega can generate several PWM signals at the same time, so you have to explain why you need an external chip.
Sun Sept 01 2013, 01:56PM
Yeah, in fact the ATMega's onboard PWM would probably do it better than any add-on chip I could think of.
Sun Sept 01 2013, 07:47PM
Sorry, Didn't mean PWM, Basicly, i want to be able to enter the frequency and duty cycle into my ATMega, it would then give me the Duty Cycle and Frequency I wish as a Square Wave, thats all.
(I want to use this as a controller for my H-Bridge)
Sun Sept 01 2013, 08:20PM
Well, when you take a square wave and adjust the duty cycle, that's PWM isn't it? tongue Or do you mean it in the Tesla coil sense, the duty cycle of the waveform is 50% but it only runs some of the time.
The ATMega's timers should be able to handle it either way.
BigBad
Sun Sept 01 2013, 09:32PM
The ATMega is the chip in the arduino isn't it?
As I understand it, the built-in PWM is sampled at 2ms, so you can only get 500hz out of it.
However, a software timed thing can toggle an output pin much, much faster; but then the chip can't do much else, but that may not matter.
What do you want it for?
Sun Sept 01 2013, 10:31PM
BigBad wrote ...
Already Stated that :)
__=|(:3)-|--{__ wrote ...
Mabye i should go back to this project at a later date.... got another thing that i think could be more useful... Anyone got any good links / directions to Powersupply Design? (Always wanted to make my one powersupply!)
(I still wouldnt mind knowing what chip for this however...)
