  • Guests: 44
Jyardana (41)
Gunboat (72)
09/17 Jyardana (41)
09/17 Gunboat (72)
09/19 raff (48)
Which induction Heater to Build?
Jazzman56
Sun Sept 08 2013, 09:30AM Print
Jazzman56 Registered Member #7222 Joined: Sat Oct 13 2012, 06:04AM
Hi Guys,
I'm looking at constructing a smallish reliable induction heater (around 200w) for a physics teachers demo to explain and teach about Eddy currents/ hysteresis / Len'z law / Transformers / Induction etc. (something that i can actually "see" working not just some theory someone came up with).
In order reduce RF noise i must also construct som sort of faraday's cage to prevent unnecessary interference.
Although i'm getting quite confused which design is best in order to achieve this.
Can someone point me in right direction please.
is this somewhere good to start?: Link2 or Link2 ?
Regards,
Jazzman56
Sun Sept 08 2013, 02:31PM
Yes, the "zvs driver" should do the trick for 200 watts. It just needs a heavy mains transformer, or an SMPS to power it, but the circuit is very simple and can be made reliable.
Mon Sept 09 2013, 03:55AM
I have to plug my design
You can build the first circuit without the microprocessor and scale it up or down as you wish. The inverter circuit is simple. You can use a pot to tune with an oscilloscope. You can power it from 120vac and take it up to 1000W easily with a variac.
If anything, there is plenty of theory for you to read.
