  • Guests: 78
Ian (37)
Lucas (40)
01/31 Mathias (42)
01/31 slash128v6 (53)
02/01 Barry (71)
Fourier college class, Stanford EE 261
Thu Aug 29 2013, 11:35PM Print
I have been watching class lectures by iUniversity for a Fourier transforms class. Every now and then I like doing stuff like this. I was going through a problem set and reviewing the solutions after doing most of the work. I have a problem understanding one solution and was hoping there is someone with enough of a mathematical background to explain this to me:
Here is the link
You need to go to page 17.
I will include a screen shot. My question is how does the final expression equal zero? No matter what value of N is picked I don't see this.
49 Pm
Andy
Thu Aug 29 2013, 11:43PM
del
BigBad
Fri Aug 30 2013, 01:19AM
You're just adding up the vectors that go along the sides of a polygon. Once you've gone around the perimeter of the polygon you're back where you started; the total vector is 0 + i 0.
Each vector is of the form e ^ i 2 Pi k/N = cos (2 Pi k/N) + i sin (2Pi k/N) where N is the number of vectors, and it's the k'th vector (from 0 to N-1).
I'm not sure off-hand where they got the second step from, but the last step is simply e^i 2Pi = cos (2Pi) + sin(2Pi) = 1, so 1-1 = 0 on the top.
Fri Aug 30 2013, 03:44AM
Thanks for clearing that up. I was so fixed on the denominator and N I forgot to figure out the numerator is zero. The rest of the problem was no problem.
Thanks again.
