  • Guests: 51
Ian (37)
Lucas (40)
01/31 Mathias (42)
01/31 slash128v6 (53)
02/01 Barry (71)
Pressure Test, Need Help Setting Up A manometer.
Fri Aug 23 2013, 06:22PM Print
im wanting to setup a test apparatus to verify a optimal design of a propeller shroud with a curved inlet.
My Question Is: How do I posistion my differential manometer probe tube, the one nearest the prop? this diagram should help.
1377282153 2431 FT0 Bellmouth1
I need the first probe on the curved upper surface, and the second probe to be at the propeller face. the ideal condition will be reached when the meter sees zero pressure differance. So do I worry about the probe tubes seeing turbulence and thus seeing bogus pressures?
1320532915 2431 FT1630 Sam 0447
My anemometer and manometer.
Should I just have both tubes' cross-sections perpendicular to the airflow direction, and hope for the best? The venturi tube examples are diagrammed very simply...
This is what im thinking of:
1377283793 2431 FT1630 Duct
This is a pic from a PDF posted from a fellow 4hv'er :
1377284711 2431 FT1630 Duct2
it doesn't mention pressure sensors, but seems to show an array of tubes on the lower left of the duct.
Sat Aug 24 2013, 06:34PM
fabrication continues.
1377369294 2431 FT156610 Carbonduct
S2 fiberglass, balsa, and carbon fiber duct curing. ill cut 4 ducts out of this one tube.
1377369294 2431 FT156610 Carbonduct2
ill use an 11 inch diameter prop with the tips cut off.
im still looking for a fliud flow modeling program thats free or cheap.
Andy
Sat Aug 24 2013, 08:47PM
Hi Patrick, I would have the red one at the bottom of the vent, this design might be more powerfull
1377377240 4266 FT156610 Airduct
The pressure of the exiting air, should be at the same pressure as the surround air, for max power, and you want virtual stationary air(stagnation) at the prop, so design the bulge to slow the speed down v1/v2=p1/p2, using (50% of prop velocity(m/sec)
Hope it helps
EDIT
v = (p1*A)/m
F = m*v2+(p1-p2)*a/m
Tip speed 124m/sec
p1 = v*A/m
62m/sec*0.003m3/0.00367kg/m3 = 50MPa
62m/sec*0.009m3/0.00367kg/m3 = 152MPa
V1/v2=p1/p2
50 p1 / 152 p2 = 0.328 ratio
62 m/sec /0.328 ratio = 189.02 m/sec
Thrust = 0.00367*189*189+(102)*0.003/0.00367
190 Newtons @ 0.003m3 area pipe @ 0.009 area bulge @ sea level = 19kg
area of max throat size would be 0.003*500 = 1.5m3 :)
50MPa -> 0.101MPa
Chamber to nozzle area ratio
inf
3.5
2.0
1.0
Throat Pressure %
100
99
96
81
Thrust Reduction %
0
1.5
5.0
19.5
If the pipe doesn't have a expansion nozzle, it will loss 20% of power, any more than 4 times the area is a waste.
Sun Aug 25 2013, 01:50AM
Andy wrote ...
Hope it helps
your statements intrigue me, im still trying to understand your math in the pic. but i may need to run two tests. one as you illustrate, to verify the coupling of the exhaust, but the other to verify the intake curve is right. i think?
1377396102 2431 FT1630 Propm
tip speed: 124 m/s
Andy
Sun Aug 25 2013, 04:05AM
Still reading this stuff, but here is some info about nozzoles
1377403550 4266 FT156610 1
1377403550 4266 FT156610 2
1377403550 4266 FT156610 3
Andy
Sun Aug 25 2013, 04:07AM
pic
1377403637 4266 FT156610 4
1377403637 4266 FT156610 5
Sun Aug 25 2013, 04:19AM
very cool pics, im continuing to look through them.
but, do you know of a free or low cost air flow simulator? im trying to figure out the curve needed on the top of a duct.
1377408057 2431 FT1630 Rotor
im also looking at panel modeling, let me post this graphic.
1377454104 2431 FT1630 Airflow
1 Pawnee 2
look at how rounded the upper duct edge is...
Andy
Sun Aug 25 2013, 10:37PM
The second picture down would be the best bet, but with the prop high up near the top of the duct.
It doesn't matter much for the curve at the top, it could be right angles and you'll only lose like 5%, if you want you could use the last scanned page but inverse the dimensions for the duct.
Mon Aug 26 2013, 03:15AM
Andy wrote ...
so, is there a way to calculate the lower parabola? or do I just geuss and check with a manometer? (im still looking at your math, and I see you want the pressure equal and max velocity at exhaust.)
fabricating these ducts is difficult, long, and expensive. so id like to calculate or simulate first to find optimum conditions.
Andy
Mon Aug 26 2013, 03:28AM
Hi, if you fill a bucket with water or a slow drying glue, and spin it up, it will make a parabola, based on what speed is the angle
y=ω2x2/2g
w = radial velocity
x = distance from center
g = 0.98
y = 60
w = 2*pie*r/1sec
r = distance from centre
]par.zip[/file]
