  • Guests: 51
Ian (37)
Lucas (40)
01/31 Mathias (42)
01/31 slash128v6 (53)
02/01 Barry (71)
Wireless LEDs brighter while touching ground?
Chip Fixes
Thu Aug 15 2013, 07:10AM Print
So I wired together some LEDs like so Link2
When I bring the LEDs close to my Slayer Exciter they light up like they're supposed to and when I move them like 6 inches away they go out. But if I connect a wire from anywhere on the LEDs to the ground pin on my PSU (shown in schematic) and touch the LEDs they will still light up several feet away from the Slayer Exciter while it is running. Why is this?
I connected the wire to mains ground instead of the power supply and the LEDs wouldn't light up.
They also won't light up several feet away if I take out the wire and won't light up if I have the wire hooked up but don't touch the LEDs.
Thanks in advance for any insight.
Thu Aug 15 2013, 11:50AM
id remove the diode, cause the LEDs already act like diodes really.
Chip Fixes
Fri Aug 16 2013, 03:50AM
The LEDs light up much farther away with the diodes included than if they are replaced with LEDs.
BigBad
Fri Aug 16 2013, 08:53PM
Greater capacitance?
This wireless technique uses capacitive coupling from the transmitter. Your body has greater capacitive coupling to the transmitter than the bare wire.
Chip Fixes
Sat Aug 17 2013, 05:23PM
Okay, I thought it might be something like that. Is there an easy way to duplicate the effect?
Ash Small
Sat Aug 17 2013, 06:16PM
Chip Fixes wrote ...
Connect a capacitor across the diodes?
Sun Aug 18 2013, 02:24AM
E.TexasTesla Registered Member #4362 Joined: Sat Jan 21 2012, 03:44AM
Your post reminds me of the time I set an old laser pointer on my sstc toroid.
It lit up and was shinning on the wall. It would be cool to buy a bunch of defective led chips
and glue them around the toroid or strike rail.
BigBad
Sun Aug 18 2013, 05:26PM
Use bigger plates for the transmitter and receiver rather than just wires, also, higher voltages at the transmitter and better Q all round are highly desirable.
