  • Guests: 37
Phlatlight 12W LEDs
Thu Aug 01 2013, 10:23PM Print
Hi all.
So I received 3 of these units this evening, thanks to Mr Dtr-lpf on Ebay smile
Interesting to note that despite one of the units having slight damage to the die the performance seems the same at least with 1mA in, I have to make a proper power supply for it as **link** is typical here.
Possibly a cosmetic issue during manufacture?
These units differ from the normal PT-54 as they have Peltier units built in.
The assembly has copper on both sides so ideal for cascades and my upcoming attempt at the Tc record.
Pics below :)
1375395838 96 FT0 Photo0424
1375395838 96 FT0 Photo0425
1375395838 96 FT0 Photo0422
Fri Aug 02 2013, 03:04PM
Those are the modules out of casio projectors, quite a bit of red light! The copper tecs are quite nice, I am surprised that not many people have experimented with them, since with (low melting point solder at least) you can solder little things directly to them.
Adam Munich
Sun Aug 04 2013, 05:08PM
Personally, I had one of these still run with the die cracked clean in half. However, be careful with surge currents, because they certainly don't enjoy them.
Meatball
Tue Aug 06 2013, 04:53AM
Meatball Registered Member #2401 Joined: Mon Sept 28 2009, 04:25PM
An SST-90 LED driver from kaidomain drives these things quite nicely - you don't really need anything fancy.
