  • Guests: 41
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
Musical microwave oven transformer?
teslarevolution
Sun Jul 07 2013, 10:37PM Print
teslarevolution Registered Member #16903 Joined: Thu May 09 2013, 08:00PM
ok i've had this idea but never tried doing it but is it possible to rectify the mains voltage feed it in to a mot through a mosfet and switch the mosfet on and off to make music much like a tesla coil?
Sun Jul 07 2013, 11:19PM
If you rectifiy the mains voltage and feed it through a MOT, you are essentially putting DC into a transformer which is not possible.
If you mean to modulate the input voltage to a MOT with audio frequencies, that will not work either. The core of a MOT is designed for 50/60Hz operation. You will saturate the core with high frequency (audio) input signals.
You can rectify the output of a MOT, and then modulate that DC voltage. There are many types of high side modulation schemes available for that type of set-up. Mostly used with vacuum tube amplifiers.
Also, that's basically how high-side vacuum tube audio tesla coils work. Generally an audio modulation transformer is used at the plate voltage side with a push-pull circuit to modulate the plate voltage to the tubes. Sue Gaeta did a very nice demonstration of this about 10 years ago. If you search for her name, you may be able to find some information about her high side VTTC audio modulation coil.
MR-ZAPPY
Tue Jul 09 2013, 09:11PM
MR-ZAPPY Registered Member #16018 Joined: Fri May 03 2013, 07:19PM
You could just modulate a flyback which would be much simpler
Wed Jul 10 2013, 08:40AM
The core will not saturate with high frequencies. The problem is that the arc would go out all the time during zero crossings and silent passages, you need an arc with idle power which is able to keep it burning. This is possible only by modulating a DC voltage, or with a carrier wave.
Wed Jul 10 2013, 02:30PM
Uh, the core WILL saturate with high frequencies. You put 20kHz in a closed core that's designed for 50/60Hz, it WILL saturate.
Tetris
Thu Jul 11 2013, 04:29PM
I think even if you managed to do that without destroying the MOT, it would be drowned out by 60/50hz hum.
Fri Jul 12 2013, 01:31PM
EasternVoltageResearch: The core will not saturate with higher frequencies, but with lower ones than the core was designed to work with (while keeping the same voltage and waveform). At a very high frequency, the flux density in the core will be very small. Psi = integral of V, where psi = N * fi is the linkage flux, "fi" is magnetic flux in the core, "N" is number of turns.
However, there would be another problem at high frequencies, and that is the winding capacitance and leakage inductance, which form a resonant low-pass filter and the high frequency would not get through the transformer.
Fri Jul 12 2013, 02:42PM
Dr. Dark Current wrote ...
Yes, you are correct. I stand corrected.
teravolt
Fri Jul 12 2013, 04:58PM
if you want to just try something you could try what Zilipoper did
using a full or half bridge and modulate it either with frequency or modulate it like a DRSSTC
the mad scientist
Tue Jul 23 2013, 06:30PM
the mad scientist Registered Member #3768 Joined: Tue Mar 22 2011, 12:46AM
ASHPoD wrote ...
Exactly, using a MOT for this is somewhat inpractical.
