  • Guests: 41
12/04 Sulaiman (71)
12/04 teslarevolution (29)
12/04 AromaZ (69)
What is the cheapest transformer that can is better that a mot
MR-ZAPPY
Wed Jun 19 2013, 08:57PM Print
MR-ZAPPY Registered Member #16018 Joined: Fri May 03 2013, 07:19PM
What transformer is more powerful than mot is cheap and common enough to get and is not a pole transformer of potential transformer
Wed Jun 19 2013, 09:24PM
The Cheapest and most common is many MOTs,
Somthing that pops up occationally is the transformers from
RF welders, usually about 2000V at 10A or there abouts from what i have seen.
In general HV transformers are hard to get hold of as they are dangerous and have very little uses.
Im persuing the HF transformers such as ferrite as they are compact and fairly cheap somtimes.
MR-ZAPPY
Thu Jun 20 2013, 03:09AM
Where can I get a rf welder transformer
Thu Jun 20 2013, 05:52AM
usually places like ebay, they arnt all that common and are VERY dangerous
Thu Jun 20 2013, 02:01PM
Sometime, the best transformer is a homemade one.
Th
Keep an eye on the RF gear net sales. My xfrm was from such SITE
Thu Jun 20 2013, 02:50PM
the MOT is easily available and has the best power-to-size ratio, it can not run continuously without cooling but for our experiments it usually doesnt matter. so more powerful than a mot are many mots.
MR-ZAPPY
Thu Jun 20 2013, 11:35PM
How many? 2-4-6-8....1000!!!!
Fri Jun 21 2013, 01:19AM
the more, the greater the power... there isnt a limit other then your budget and supidity for daring play with the mighty MOT
GrantX
Fri Jun 21 2013, 05:01AM
Indeed, the only limit is your power supply and your desired output.
I've managed to squeeze 9kVA through 2 MOTs with series resonant caps... For 30 seconds before the smoke clouds began. Drawing this much power the supply cord, ten amp outlet and the wiring all the way back to the switchboard got warm - pretty dangerous if you cannot monitor the temperature of the wiring in the wall (luckily my barn just uses PVC conduit, so it's easy to open it up to check the temperature or slip on a clamp meter).
As others have said, if you don't want to use MOTs, your cheapest option might be rewinding an existing transformer. Perhaps find a cheap welder transformer, keep the mains-voltage primary and remove the high current winding. Some welder transformers are very large, I've seen a few in excess of 10kVA.
Fri Jun 21 2013, 01:10PM
The maximum sensible power to draw from a generously sized MOT is around 1 kW, then it lasts usually around 10 minutes of runtime before getting too hot. Usually the power available at a standard house sockets is around 3 kVA, so using more than 3 MOTs is not necessary.
