  • Guests: 66
OnFire (64)
01/25 Evgenij (60)
01/25 Our Finest Hour (64)
01/25 Patrick (44)
How do I depot a NST
MR-ZAPPY
Tue Jun 18 2013, 07:07PM Print
MR-ZAPPY Registered Member #16018 Joined: Fri May 03 2013, 07:19PM
I would like to depot a nst to get a high current out but I could not find any resources. What is the most simple, most easy, fastest and cleanest method.
Thanks
Tue Jun 18 2013, 07:36PM
it would probibly be quicker to get a few FBT in parallel with a decent driver or wind your own then to go through all that.
I dont think there is any fast, clean and easy method.
only way i think is to heat it in boiling water, pull the transformer out then hang it in a oven over a container to catch the tar i guess.... or if its acctual potting, i have no clue at all.
MR-ZAPPY
Tue Jun 18 2013, 08:03PM
I have never had success with a flyback and it is probably that the transformeris dead or my soldering is bad
Wed Jun 19 2013, 12:07AM
What are you planning to do with the NST after depoting it ?
If you need higher current you could just use two MOTs in serie.
What are your exact needs in terms of V and A ?
MR-ZAPPY
Wed Jun 19 2013, 01:32AM
It's mostly just for arcs but what kind of transformer can give you monster arcs
Wed Jun 19 2013, 01:44AM
This kind Link2 ;)
