  • Guests: 54
OnFire (64)
01/25 Evgenij (60)
01/25 Our Finest Hour (64)
01/25 Patrick (44)
Can I run the gu81m filament coil on 12 volts
MR-ZAPPY
Tue Jun 18 2013, 02:25PM Print
MR-ZAPPY Registered Member #16018 Joined: Fri May 03 2013, 07:19PM
I am building a hf VTTC with the gu81m and was wondering if I could test the filament with 12 volt even though is is designed for 12.6
Tue Jun 18 2013, 03:10PM
Running a 12.6V filament at 12V will not make much difference to circuit operation, and will probably extend valve life.
Tue Jun 18 2013, 03:11PM
Yes, you will get slightly decreased power output.
Tue Jun 18 2013, 04:14PM
Detailed valve data sheets often give either a working filament voltage range for normal operation, or % tolerance, which is often specified as 5%.
12V is within the 5% tolerance range for a 12.6V filament, so there should be no important change to the valve characteristic curves given in the datasheet when operating the valve with 5% reduction in heater voltage.
From a practical point of view, the filament of your military power pentode was designed to operate across the voltage range of lead-acid 12V accumulators with
an open-circuit voltage of 2.10V x 6 = 12.6V volts, and a loaded full discharge voltage of 1.75V x 6 = 10.5V.
Tue Jun 18 2013, 05:07PM
Yes, but running the tube "the 4HV way" calls for the filament voltage near the upper limit cheesey
RateReducer
Tue Jun 18 2013, 05:52PM
RateReducer Registered Member #4603 Joined: Wed Apr 25 2012, 07:33PM
Dr. Dark Current: Do you power your filaments always near the upper limit? That could explain the massive output of your VTTCs tongue
MR-ZAPPY
Tue Jun 18 2013, 06:30PM
I have a 15 amp variac and I am worried about plugging it into the tube because the maximum filament rating is 10 amps
RateReducer
Tue Jun 18 2013, 07:06PM
Powering a GU81 filament directly from a variac is a stupid idea... No galvanic isolation from the net and nearly a short circuit when the filament is cold - your variac will not like it.
You need a filament transformer.
MR-ZAPPY
Tue Jun 18 2013, 08:14PM
12 volt battery?
Tue Jun 18 2013, 08:57PM
RateReducer: In my GU-81M VTTC the voltage on the filament is around 12.65 - 12.7V with nominal 230V in the line. The problem is the tolerance of the line voltage, it is very common to get 240V here. If I was to stabilise the filament voltage, I would dare to go higher... but I almost never do this :D
