  • Guests: 41
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Need advices before buying an expensive Variable Vacuum Capacitor
Wed Jun 19 2013, 10:10PM Print
Hi all,
I need an advice ... I would like to buy a Variable Vacuum Capacitor
I plan to use it for various small/mid size VTTCs (572B, GK71, GU81M) powered with a 2480V MOT (with eventually voltage doubler, full wave rectification, smoothing)
With full wave rectification my power supply is around 2480 x 1.414 = 3500V
With voltage doubler it goes up to 7000V peak
But I wonder how high the voltage at tank capacitor can climb due to oscillation and resonance
There are two "ranges" of operating voltage for these VVCs:
- 10kV nominal / 15kV peak / 20kV peak test
- 25kV nominal / 35kV peak / 50kV peak test
Basically my question is: is a 10kV nominal enough for my needs or shall I get the 25kv nominal one ?
Thanks for your advices :)
MR-ZAPPY
Wed Jun 19 2013, 10:14PM
MR-ZAPPY Registered Member #16018 Joined: Fri May 03 2013, 07:19PM
Just to be safe I would get the 25 kv one
Wed Jun 19 2013, 10:49PM
Mr.Plasma-CRAZY wrote ...
Agreed with that
My dilemna is the max value I found @25kV is 200pF, while there are 500pF and 1000pF models @10kV
And of course I would prefer the max capacitance
That's why I'd like a precise answer...
MR-ZAPPY
Wed Jun 19 2013, 10:59PM
If they do not cost much you can put 2 in series in parallel with 2 in series
Wed Jun 19 2013, 11:06PM
They do cost a lot ! (around $200)
MR-ZAPPY
Each?
Antonio
Wed Jun 19 2013, 11:32PM
If you don't need the full range of adjustment you can just place a fixed capacitor in parallel to have greater capacitance.
Thu Jun 20 2013, 12:08AM
Each?
Yes
Antonio wrote ...
If you don't need the full range of adjustment...
I need it. That's why I wanna invest into a VVC
Myke
Thu Jun 20 2013, 02:06AM
You can swap in different fixed capacitors with the single variable capacitor to get a large range of capacitances... unless you need to have it smoothly adjustable while it's on (you could even swap out the caps with high voltage relays if needed).
Thu Jun 20 2013, 04:09AM
Myke wrote ...
unless you need to have it smoothly adjustable while it's on ...
Well yes this is my goal
And the larger the VVC capacitance, the better. Hence my initial question
