  • Guests: 34
12/04 Sulaiman (71)
12/04 teslarevolution (29)
12/04 AromaZ (69)
300 W iron high-voltage transformer pig, overclocked to 18 kHz from full bridge
zilipoper
Tue Jun 18 2013, 04:17PM Print
zilipoper Registered Member #4152 Joined: Thu Oct 20 2011, 10:18PM
hi
it is a regular iron 50Hz transformer included from 18 kHz inverter
power transformer core 300 W ;DDD
is pumped power iron on 18kHz 100 kW o____________O
I don't know what there loss iron core, but arc evil and hellish ;D
1371572120 4152 FT0 Dej67tpbc Q
1371572120 4152 FT0 S3caspoag7y
8q5phiy
1371572159 4152 FT0 Iw2jqwxafka
1371572159 4152 FT0 Nno2posmoco
1371572159 4152 FT0 Sq7sej9qmre
1371572159 4152 FT0 Vkv266xx1ho
MR-ZAPPY
Tue Jun 18 2013, 04:29PM
MR-ZAPPY Registered Member #16018 Joined: Fri May 03 2013, 07:19PM
What kind of transformer is that
zilipoper
Tue Jun 18 2013, 04:34PM
30 kV from the laser
teravolt
Wed Jun 19 2013, 03:01AM
stunning, is it a standard iron core? I don't think it is supposed to do that! What does the driver look like?
zilipoper
Wed Jun 19 2013, 05:56AM
hi teravolt
core of the transformer from the ancient tube TV
1371621303 4152 FT155059 9acc02020f83
the driver of the bridge on igbt inverter 150A
the mad scientist
Wed Jun 19 2013, 03:34PM
the mad scientist Registered Member #3768 Joined: Tue Mar 22 2011, 12:46AM
That is amazing, wish I had one like that.
RateReducer
Wed Jun 19 2013, 03:50PM
RateReducer Registered Member #4603 Joined: Wed Apr 25 2012, 07:33PM
I have a transformer form an X-Ray power supply. It also has an iron core (with very thin metal sheets!!!) but it is not meant for 50Hz operation. It was driven buy 2 Thyristors... Did not understand the driver ^^
I tried to run it on 50Hz but absolutely nothing happend - the primary of the transformer is just a short circuit on 50Hz. It worked fine with a IGBT halfbridge on a few kHz.
zilipoper: Very cool arcs! amazed Are you sure your transformer is build for 50Hz? Did you try running it on 50Hz?
zilipoper
Wed Jun 19 2013, 04:36PM
of course it is 50Hz I can't be wrong;)
the mad scientist
Wed Jun 19 2013, 04:51PM
Can you please tell me where you got all the supplies to make that, like where can I order that stuff online? The core, the wire, the case and so on.
MR-ZAPPY
Wed Jun 19 2013, 05:11PM
I really should get one of those transformers. If I understood you correctly it is a hv transformer for a laser tube?
