  • Guests: 49
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
VFD tubes
RateReducer
Sat Jun 15 2013, 02:27PM Print
RateReducer Registered Member #4603 Joined: Wed Apr 25 2012, 07:33PM
Hi. I am building a VFD clock with 4pcs IV-11 tubes.
How can i dim the brightness of the tubes and how can i get the maximum lifetime?
Reducing the filament/anode voltage?
here is a schematic: Link2
In this circuit a LDR is used - to adjust the brightness to match the illumination of the environment ?
Edit: what about PWM on the anode?
Greetings
Sun Jun 16 2013, 06:25AM
Hi, yes PWM would reduce the brightness.
Heater voltage and current needs to be kept within spec to have good tube life, 3.6V AC and the heater should be barely visible in a dark room.
-A
RateReducer
Sun Jun 16 2013, 12:50PM
Okay. I have a IC which drives the VFD tubes. It works with multiplexing...
Would it work if i choose a high PWM frequency and modulate the multiplexed signals form the IC with mosfets!?
Tue Jun 18 2013, 05:50AM
Should work.
Most ICs include a blanking input that can also be used.
