  • Guests: 76
oucivileng (39)
01/26 oucivileng (39)
01/27 muller (38)
01/27 Dr. Mario (38)
questions about steves half bridge flyback driver
MR-ZAPPY
Fri Jun 07 2013, 07:40PM Print
MR-ZAPPY Registered Member #16018 Joined: Fri May 03 2013, 07:19PM
can this driver output high current arcs. also do i use the original flyback primary or can i make my own primary but how many turns and what AWG should i use. can i parallel the MOSFETs so that i can give it more power.
also how do i build the GDT
i also have attached the schematic
1370634020 16018 FT0 Half Bridge Driver
HDF49
Fri Jun 07 2013, 08:01PM
HDF49 Registered Member #977 Joined: Thu Aug 30 2007, 06:57PM
It's a matter of experimenting with the turns fpr your particular flyback as far as I know. Here's a good bit of info on GDTs, there's plenty more out there Link2
Fri Jun 07 2013, 11:42PM
This circuit is just your general run of the mill half-bridge circuit. The primary on the flyback needs to be optimized for the particular flyback being used. One, you don't want to overvoltage the secondary and arc the secondary windings so you need to be careful about how much voltage you drive the half-bridge with.
