  • Guests: 49
Barry (71)
Snowcat (38)
wylie (44)
02/03 Bauerb2 (36)
02/04 Fabio (46)
02/04 Corey (35)
Are microwave oven diodes avalanche diodes?
Tue May 28 2013, 06:59PM Print
A friend of mine used some for rectification of a current limited HV transformer, but he didn't know that the diodes need to be rated at Vpeak-peak for half wave rectification. The diodes supposedly got so hot that they desoldered themselves, but still worked afterwards.
The use of avalanche diodes would make sense as I believe there are several dies in series. Making series stacks of MW diodes would then be easy without any ballancing circuits. What do you think?
Wed May 29 2013, 07:12AM
Yes, they are very probably avalanche diodes. They have a forward voltage of about 8V, so they definitely have multiple dice in series.
Wed May 29 2013, 09:18AM
Thanks for the reply Steve. wink
Alex M
Thu May 30 2013, 02:03PM
This might be useful Link2 , its the data-sheet for a diode I got out of an old microwave and it has avalanche specifications listed.
Wed Jun 05 2013, 05:19AM
Hmm.. Another idea, gut a MW diode and make some avalanche photodiodes (APDs) on the cheap.
Might work.
-A
Wed Jun 05 2013, 09:06AM
I think it would be easier to just buy a single diode.
I think probably pretty much any diode would do something interesting when biased near to its reverse breakdown voltage and exposed to radiation. Even non-avalanche-rated diodes (1N4007 etc) can withstand a small current in the avalanche mode.
Wed Jun 05 2013, 05:41PM
(scuttles off to test this idea..)
Didn't some old TVs use this method to detect X-ray leakage from the rectifier tube and shut down?
-A
Wed Jun 05 2013, 10:00PM
Probably not, tube rectifiers in TVs were obsolete before automatic shutdown circuits were introduced. Tube TVs protected against X-rays by using a thick leaded glass envelope for the rectifier tube.
Tue Jun 11 2013, 05:04AM
Heh. Link2
OK so it doesen't actually detect X-rays but senses excess HV that can cause X-ray emission and also crack the glass.
Thats intriguing..
Wonder why they used to put a warning on camcorder viewfinders when the HV was below 3.5KV even in the event of total HV runaway? I once tried this and overran one with a bad vertical output to 14V in and the HV only went up by an estimated 10%.
(scuttles off to go and find the salvaged B/W CRTs to see if they have a warning label too)
-A
