  • Guests: 40
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
ZVS flyback trouble
HDF49
Sun May 26 2013, 04:18PM Print
HDF49 Registered Member #977 Joined: Thu Aug 30 2007, 06:57PM
I just hooked up my ZVS to a 2 Amp variac transformer, I ran it at about 30 volts and around 400 watts for a bit, absolutely huge sparks then it stopped working. It's made from irfp250s, 12v 0.25 watt zeners and uf4007 diodes, which of these will have fried? The mosfets got warm but not too hot, I doubt it's them, but if the diodes have gone will that have left the mosfets unprotected and fried them too? I'm looking to rebuild it and run it off an 8A variac I have, but I want to make sure all the components I have are up for it, so will the irfp250s be ok for that kind of power? And what diodes will I need for it?
Harry
Sun May 26 2013, 05:23PM
Harry Registered Member #4081 Joined: Wed Aug 31 2011, 06:40PM
Are you sure the flyback isn't dead? You could try another flyback with the same driver to identify the problem.
HDF49
Sun May 26 2013, 05:57PM
Positive, I have 4 and have tested them all
Kiwihvguy
Tue Nov 05 2013, 12:12PM
Kiwihvguy Registered Member #3395 Joined: Thu Nov 04 2010, 08:42AM
Any luck since? If you have confirmed each flyback is working, then it has to be one of the components. Test your fets and diodes.
brandon3055
Wed Nov 06 2013, 07:27AM
0.25w zeners seems a bit small. If I had to guess I would say its those
HDF49
Wed Nov 06 2013, 12:28PM
Yeah all sorted thanks, it was the zeners going then killing the mosfets with a big signal on the gates
Kiwihvguy
Fri Nov 08 2013, 11:00AM
No worries, usually the zeners die when the fets go or vice versa. Myybe next time replace the zeners with TVSs, much much faster.
