  • Guests: 37
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
Gate drive signal
1 2 3 4  last
furnace
Tue Oct 22 2013, 07:18AM Print
furnace Registered Member #4992 Joined: Wed May 23 2012, 03:57PM
Can anyone give some advise on this gate drive signal which i cant seem to get fixed for my indution heater.
Im running a 600v 150A IGBT half bridge brick with a pll ic which is driving my tc4421 and tc4422. I have a
1:1:1 gdt and on my secondary i have 3ohm resistors with zenor diodes.This is also powered from a 15v regulated
power supply.
41
Tue Oct 22 2013, 10:13AM
Parasitic oscillation?
furnace
Tue Oct 22 2013, 11:52AM
Thanks, but it seems that there is very little info on this topic and i dont fully understand steves answer on the topic
where he states that you should use a half bridge drtven by a pll. Is this not what im doing? or does it mean that that i should
take away my tc ics and add a half bridge, if so! is there a shematic i can follow or do i totally have it wrong or is there another way
of fixing the oscillations?
TwirlyWhirly555
Tue Oct 22 2013, 12:55PM
TwirlyWhirly555 Registered Member #4104 Joined: Fri Sept 23 2011, 06:54PM
Are you driving a GDT with the TC44** drivers ?
furnace
Tue Oct 22 2013, 01:13PM
Yes.
furnace
Wed Oct 23 2013, 07:46AM
Is there no one that can assist me with this?
Andy
Wed Oct 23 2013, 08:00AM
It looks like a couple of pF and inductors are draining, a tune circuit I think, whats the cabling like to the gate. Have you got a circuit diagram. I tried making a marxs with a cable from the opposite direction to the switch connect to the inductors, made a wave form like that. If its warth anything.
furnace
Wed Oct 23 2013, 09:42AM
Im using 0.5mm solid wire on my gdt which is twisted together and im working on mindchallenger schematic.
The only thing substituded was the 39000 uf cap for a .22 nf 500v on my 15v regulator.
Jrz126
Wed Oct 23 2013, 10:12AM
So how much capacitance do you have on the 15v supply?
Check it right at the TC** chips. My guess is your 15V rail isnt smooth.
furnace
Wed Oct 23 2013, 10:54AM
Believe me, i have checked and i have the wright capacitance at the tc chips which is 1uf.
1 2 3 4  last
