  • Guests: 39
M.A.D. (32)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
High side Ic problems
Ben Solon
Sun May 19 2013, 01:17AM Print
In the past I've built plenty of inverters driven by bootstrapped high side type drivers successfully. For the past few days I've been trying to get the driver on my breadboard working properly, but its being stubborn. I'm using the fan7392 driver, and the high side output just isn't driving...
I've gone through everything I've thought of, so any new thinking would help. The inputs are fine, perfect alternating square pulses from an sg3525, no problem there. The low side is fine, and when the high side section is hooked up directly to vcc and gnd it outputs just like a low side driver. So there aren't any internal issues. When hooked up as indicated in the data sheet, the simplest of implementations, the entire high side section(all the pins) go to vcc. But no output.
I've swapped diodes and caps multiple times, and I'm convinced everything is fine. I even tried different driver ic's and they all give me the same issue.
Any ideas?
Sun May 19 2013, 01:47AM
I need an exact schematic.
Ben Solon
Sun May 19 2013, 01:50AM
Patrick wrote ...
take a look at the datasheet. diode is 1n4148/sb160, and the cap is .1u/10u.(different parts/values to test with)
Ash Small
Sun May 19 2013, 10:28AM
Presumably you've read the notes regarding stray inductance, etc?
]fan7392.pdf[/file]
Ben Solon
Sun May 19 2013, 02:01PM
Yes, and for getting the circuit working none of it should really matter other than the sizing of the bootstrap capacitor. Uvlo was another concern, but I raised the supply to just under 20v to be sure. I have no series resistor. I have no need to limit inrush current at this point, and in the past the circuit has worked fine without it.
Wolfram
Sun May 19 2013, 02:20PM
Is the bottom MOSFET/IGBT present? The bootstrap circuit won't work without it.
Sun May 19 2013, 03:18PM
Yup, the high side won't do anything until the bootstrap capacitor has been charged by turning the low side on for a short time.
Ben Solon
Sun May 19 2013, 07:31PM
Yep, I have both fets floating for test. The high side vcc, gnd, and the output almost look like common mode noise from the low side, but its not. There is a square wave of ~1v pk-pk floating at 18v. It's common between all high side pins, but the vb pin is a volt or two higher than vs and vo.
Avalanche
Sun May 19 2013, 10:09PM
I know you said you'd raised the supply voltage to make sure you're over any uvlo thresholds, but try probing directly across the bootstrap capacitor (Cboot) if you haven't already, to make absolute sure the bootstrap operation is working. That chip appears to have separate undervoltage shutdowns for high and low side, and Cboot needs to be at about 10 volts to work.
Only suggesting this because I've wasted about half a day before on a very similar problem, and from what you've described this is about all it can be!
Tue May 21 2013, 10:02PM
[blockquoteYep, I have both fets floating for test.[/blockquote]
That sounds like the problem.
You need to have the fets connected as a half-bridge, and you need to turn on the low side fet first to charge the boostrap capacitor for the high side driver. I cant tell if this is clearly understood by you or not but it sounds like it fits the bill for explaining your problem.
