  • Guests: 29
M.A.D. (32)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Turning fan off at lower temperature?
Alex M
Tue May 21 2013, 01:35AM Print
Hi all,
I am trying to come up with a small temperature controlled fan circuit for the thermal management of a project I am working on. So far I am just using the old comparator method which turns the fan on and off depending on the state of a thermistor.
Here is a basic representation of what I currently have.
1369099949 3943 FT0 Fan Control
Now that works fine but I would prefer having the fan come on at a high temperature and then turn off at a much lower temperature. Does anyone know how this could be done?
Cheers.
Alex M
Tue May 21 2013, 03:57AM
Update: This seems to work.
1369108555 3943 FT154047 Fan Hythresis
A bit of hysteresis, VR1 sets the "on temp" and VR2 sets the "off" temp. Very easy to adjust with an oscilloscope for visual reference.
Tue May 21 2013, 11:42AM
Yes - make sure you use hysteresis in your design. Simulating in PSPICE is a good way to see how the hysteresis works with your particular project / thresholds. 5 degF of hysteresis is probably good.
Billybobjoe
Tue May 21 2013, 11:00PM
Just for others to note: I think you've got your comparator connections flipped if you are indeed using a NTC resistor. If it works I'm assuming you hooked it up correctly in your actual circuit.
Alex M
Wed May 22 2013, 02:05PM
Billybobjoe wrote ...
Opps, you are correct they are flipped. Here is the corrected one.
1369230521 3943 FT154047 Fan Hythresis
EasternVoltageResearch wrote ...
Thanks EVR. 5 degF sounds about right to what I have set it to.
With out hysteresis the fan would come on for about 10 seconds and then turn off for the same amount of time, whilst this technically did the job it was quite annoying acoustically.
Wed May 22 2013, 07:24PM
You can go super low-tech with just a thermal switch and fan e.g. Link2
My last hobby temp.controlled fan/heatsink I used a threaded thermistor Link2
passing about 1mA through the thermistor (<80C <600R, hotter >10k)
across base-emitter of a transistor as a switch, emitter=ground and collector to load.
I used it as an alarm/shutdown but it (or similar) could just as easily control a fan,
don't forget, collector current=load=Fan current <= 1mA x current gain of transistor
maybe a darlington with c2mA would be better for a fan controller.
Mechanical/Thermal switches have intrinsic hysteresis,
adding hysteresis when the sensor has none is always a good idea,
in this case the natural thermal inertia time constant of the fan/air/heatsink
( heating with fan off and cooling with fan on, with potentially varying heat input ) would probably be in the seconds range ... quite annoying.
(hence variable speed fans)
Any transistor (e.g. npn with collector-base short) that can be fixed (thermally bonded) to the heatsink can be used as a temperature sensor (diode law)
if you use the same transistor type as a 'cold junction' (pass about 0.1 to 1 mA ea.)
you should get near zero voltage difference between the two diodes with heatsink at room temperature, the heatsink diode voltage will drop as temperature increases .....
I only mention it because physically attaching thermistors to heatsinks needs some thought, small transistors that can be screwed/clipped/etc to your heatsink are probably in your 'spare parts', if not very cheap. Using a similar transistor as the cold junction means it can dissipate 0.1mA at 600mV with negligible self-heating,
or easily 'attached' to ambient (grounded metalwork, casing etc.)
For a one-off comparing heatsink diode voltage with a reference voltage is good.
