  • Guests: 33
Friday (55)
robismor (30)
07/13 Friday (55)
07/13 robismor (30)
07/14 EEYORE (42)
I am in possesion of two XV-11 LiDAR units.
Fri May 17 2013, 06:12PM Print
i have two lidars.
XV-11, neato robotic vacuum cleaners.
each one weighs in at 192 grams.
overall height is 2.2 inches.
width is 3.8 inches.
length is 4.6 inches.
range is 6 meters (or 19.5 feet.)
im thinking of using Parallax Serial Terminal, or Termite.
data rate is 115.2 kbps, RPM is 5 to 10 Hz, resolution is 360 points per rotation (1 Deg) and sequential unlike the Hykoyuo's. This device uses the DLIS-2k linear sensor, which I wish I could buy. And a IR dot laser. Im planning to use my logic sniffer to verify there working.
source sites:
Link2 wiki lidar, for supporting external devices.
Link2 motor control for Lidar.
1368815563 2431 FT1630 Lidar1
1368815563 2431 FT1630 Lidar2
1368815563 2431 FT1630 Lidar3
1368815563 2431 FT1630 Lidar4
Carbon_Rod
Sat May 18 2013, 06:10AM
These are not LIDARs, but distance sensors which operate on a similar principle of the Sharp GP2Y0A02YK0F.
(IIRC, these had a CCD element inside similar to old desktop optical scanners)
The repeatable measured resolution one would need for SLAM will likely be difficult to achieve.
wink
Best of luck,
Rod
Sat May 18 2013, 01:46PM
Carbon_Rod wrote ...
close enough, using laser light to measure distance = a lidar, in my book.
wink
nope, the vacuum navigates just fine, my C-slam (input) isn't more demanding than the original Vacuum claeaners'.
in fact the C-slam [source, onSTM32F4] worries me more than the lidar at this point. (I may need some forum members to help figure / advise me on how to implement the C-SLAM source)
my speed shoud be a game changer in the compititon, the hykoyos are expensive, and all the ones ive seen use USB, so Theres a support PC on board taking the lidar+USB, then transmitting wirelessly to ground PC base station, then SLAM and decision making made on the ground, with results being transmitted back to the craft in flight.
in the mean time due to latency, even the high $ Michigan university team, has crashed face first into walls, due to long loop time.
my system will be more primitive than the 6500 US$ Hykoyou, but entirely an embedded solution. (remember USB is evil, if you don't have a custom driver, or an existing one. I was told by an ace programmer and MS/PhD group, don't even try to write your own USB driver, or youll be psychotic soon enough.)
Carbon_Rod
Sun May 19 2013, 02:01AM
Some $1.7k models by Hokuyo had a regular rs232 on the same plug as the power inputs.
SLAM is resource intensive, and I doubt an STM32F4 kit will have the capacity to do this successfully....
USB is easy if your board has a real operating system with a host stack....
Commonly, people's goal “to win” often gets misinterpreted as “building a better sensor platform”.
Sometimes complexity loses the challenge before it even starts:
Sun May 19 2013, 02:21AM
yes, but I don't think those are made any more, and they seem to go fast when they appear on ebay and such.
I worry about this fact every night before I go to bed.
only if the original device maker, wrote the USB driver, and its for a compatible system, the other groups use normal win or Linux driver on the "GumSticks" type computers.
I am open to better solutions, and would beg anyone for a solution that avoids traditional slam, in fact im wondering if I should just "hand hold" the wall all the way around the course.
EDIT: I must admit, maze theory does look interesting.... however, attrition and inefficiency of path planning worry me.
EDIT: heres a graphical example of the office space we must navigate, the "hostile foreign nations center for torture and ministry of defense".
maze
1368933439 2431 FT1630 Maze
the drone takes off and lands at the red window, but the flash drive is the blue spot.
