  • Guests: 65
Noelle (43)
King_of_Junk (36)
Ixz (35)
geobruce (31)
tulkas (32)
Gregory (31)
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
Geiger counter design and prospects of scintillation spectroscopy
Carbon_Rod
Mon Apr 08 2013, 09:02AM Print
Just curious if anyone knows whether its possible to differentiate the emission energy level of Geiger tube spikes.
For example, does the spark gap avalanche event settling-time differ with ionizing sources?
Cheers,
Rod
Mon Apr 08 2013, 09:21AM
Short answer: No. Geiger tubes operate in the avalanche region, every discharge is a complete discharge of the tube. Different particles may touch it off in subtly different ways, but the information is lost in the resulting chaos. Essentially you have a flattened ski resort and you're trying to figure out exactly which snowflake started the avalanche. smile
Long answer: Your Geiger tube may show a "proportional region" when it's operated below its rated voltage. Link2
Carbon_Rod
Mon Apr 08 2013, 10:07AM
Are they sampling a ramp generator (~80v to 400v) to garner “trigger” thresholds?
Would the method generalize to an alpha "spark detector"?
The Neon indicator tube in series with the Geiger tube tends to vary in intensity under background events, and it is operating at a well regulated 400v. Hypothetically, if it were completely discharged every event than when a Geiger tube enters into the saturation “glow” condition it would remain discharged. Which wouldn't make sense.... confused I am... wink
Cheers,
Uspring
Mon Apr 08 2013, 03:46PM
No you would stay with a voltage just below the point of a continuous discharge. If you want to do spectroscopy you need to pick up the pulse height. Alphas typically produce a few thousand ion/electron pairs, which are multiplied somewhat in the proportional regime. You need low noise amps to do that.
Mon Apr 08 2013, 10:13PM
Have a read of this essential GM tube theory manual from Centronics: Link2
Steve is right to say that some GM tubes can be operated in proportional mode. A few of the common Cold War era Russian GM tubes give proportional mode parameters in their data sheets. This is generally a band about 20V wide before the start of the GM plateau region.
Proportional mode requires a low noise linear pre-amp which can accurately amplify the pulses while maintaining their relative pulse amplitude. Discriminators can then sort these out into the number of bins appropriate to the practical resolution of the instrument.
Carbon_Rod
Tue Apr 09 2013, 06:36AM
I was looking into the various tubes listed on this site:
These look like interesting options, but do not seem to disclose proportional operation:
LND7317,LND712,SBT11A
@Steve
Alternately, would it be possible to avoid proportional methods by using a precision Aluminum coated mica filter wheel to selectively retard beta emission. Thus, forming a profile by automatically stepping through 0.001mm to 1.000mm shielding on the tube aperture over several hours, and removing the background profile after each exposure interval. I am curious if anyone has attempted building a similar apparatus. smile
Thanks for the link PM, I will look over the info.
Rod
Uspring
Tue Apr 09 2013, 08:52AM
Alphas have a much shorter range than betas. You can't shield against betas and not block alphas.
In a thin, transmissive type detector, an alpha will leave a higher signal than a beta due to its fatter ionisation track. If you're sensitive to pulse height, you might be able to distinguish between them.
Alternatively you could place a somewhat shielded (alpha insensitive) detector behind a thin alpha detector and use anticoincidence. A signal in both detectors will signal a beta and a signal only in the first one an alpha.
Tue Apr 09 2013, 10:49AM
The use of filtration using filters of known properties - such as a sheet of thin aluminium foil - has been a basic analytic procedure since the invention of the GM tube in 1928. At the risk of over-simplification, if all the radiation from a sample is blocked by aluminium foil, then you have an alpha only emitter. If none of it is stopped measurably by 1 mm Pb, then it is gamma rays, and so on.
A great deal more can be done with GM tubes than simply detecting the presence or absence of radiation. Have a look at this wonderful old classic from the Golden Age of gaseous detector technology:
The use of the Geiger-Müller counter X-ray spectrometer in an X-ray laboratory, with special reference to automatic recording Link2
